查看: 2514|回复: 2
1620液晶模块
发表于 2010-5-27 11:12:07 | 显示全部楼层 |阅读模式
1620-1黄绿屏超宽视域 详细说明:
    1.D: 80X36X14mm
    2.VA:63.8X15.8mm
    3.AA:55.7X11.0mm
    4.STN,Transmissive
    5.IC: ST7066U-0A,ST7065C
    6.Application: telepone,fax machine,etc......
 楼主| 发表于 2010-5-28 10:56:33 | 显示全部楼层
Q:1320862821
1620-1 普通型 详细说明:
    1.D: 80X36X14mm
    2.VA:63.9X13.4mm
    3.LCD display:transflective, positive
    4.Font size: 2.95 * 5.35 mm in 5* 8 dots
    5.IC: ST7065,ST7066
    6.Interface: 4-bit or 8-bit
    7.Power supply: single power supply(5v+/-10%)
    8.With or without backlight
 楼主| 发表于 2010-5-29 10:32:35 | 显示全部楼层
TEL:13725502976
1602Y1C-VA字符液晶模块 详细说明:
    ·型号:1602Y1C-VA
    ·控制器:S6A0069
    ·外形尺寸:83.4×37.5×9.5
    ·有效区尺寸:64.6×16.0
    ·字符大小:2.95×5.55
    ·像素尺寸:0.55×0.65
    ·背光源:LED
