查看: 3073|回复: 2
清理电脑发现里面的老文章免费分享,30个无限制下载。
发表于 2010-6-2 01:49:45 | 显示全部楼层 |阅读模式
2006年激光器市场分析.pdf (344.59 KB, 下载次数: 7)
2007年二极管激光器市场增势减缓.pdf (486.51 KB, 下载次数: 4)
Application Note Volume Bragg Grating Alignment.pdf (428 KB, 下载次数: 6)
Coupled-wave analysis of apodized volume gratings.pdf (172.53 KB, 下载次数: 4)
Frequency-narrowed external-cavity diode-laser-array bar.pdf (116.21 KB, 下载次数: 2)
High brightness laser design based on volume Bragg gratings.pdf (1.18 MB, 下载次数: 2)
High power with high efficiency in a narrow single-lobed beam from a diode laser.pdf (430.96 KB, 下载次数: 2)
High-brightness narrow-line diode source with volume Bragg-grating feedback.pdf (304.09 KB, 下载次数: 2)
High-frequency Bragg gratings in a photothermorefractive glass.pdf (100.69 KB, 下载次数: 2)
Laser Marking Mechanism and Quality Characteristics.pdf (152.62 KB, 下载次数: 2)
lm_stabilizer.pdf (290.12 KB, 下载次数: 2)
Modeling of Gaussian beam diffrraction on volume Bragg gratings in PTR glass.pdf (354.88 KB, 下载次数: 3)
Modeling of phase volume diffractive gratings part 1 transmitting sinusoidal uni.pdf (626.76 KB, 下载次数: 2)
Narrow beam divergence of laser diodes with a Bragg grating in external cavity.pdf (70.53 KB, 下载次数: 3)
Optimizing and Stabilizing Diode Laser Spectral Parameters.pdf (802.4 KB, 下载次数: 3)
Performance enhancement of the high-power laser diodes and arrays by use of the .pdf (100.38 KB, 下载次数: 2)
Power efficiency of a semiconductor laser with an external cavity.pdf (123.02 KB, 下载次数: 2)
Spectral stabilization of laser diodes by external Bragg resonator.pdf (163.4 KB, 下载次数: 2)
Thin and thick diffraction gratings_Thin matrix decomposition method.pdf (197.18 KB, 下载次数: 2)
Unexpected properties of a laser resonator with volumetric Bragg grating end mirrors.pdf (93.77 KB, 下载次数: 2)
Volume Bragg semiconductor lasers with near diffraction limited divergence.pdf (546.98 KB, 下载次数: 2)
Volumetric Bragg Grating Dramativally Cuts Laser Bandwidth.pdf (268.74 KB, 下载次数: 2)
Wavelength-tunable narrowband high-power diode laser stacks based on volume Brag.pdf (412.67 KB, 下载次数: 3)
国际激光器市场动向.pdf (98.67 KB, 下载次数: 8)
激光加工技术的发展.pdf (247.55 KB, 下载次数: 4)
激光器市场回顾与展望二极管激光器.pdf (488.96 KB, 下载次数: 7)
激光市场综述.pdf (107.59 KB, 下载次数: 6)
瓦级半导体激光器光束整形装置.pdf (87.02 KB, 下载次数: 12)
现代光学工程(en).pdf (275.76 KB, 下载次数: 5)
现代光学工程1(en).pdf (188.48 KB, 下载次数: 7)
发表于 2010-9-14 13:28:01 | 显示全部楼层
不免费啊
发表于 2010-11-25 17:55:27 | 显示全部楼层
好东西
