查看: 2761|回复: 3
激光降雨(Lasers could be used to make rain)
发表于 2010-7-6 10:45:16 | 显示全部楼层 |阅读模式
View inside the cloud chamber before (a) and after (b) firing a set of three laser shots at 100-ms intervals. Image credit: Nature Photonics, doi:10.1038/nphoton.2010.115
(PhysOrg.com) -- Optical physicists in Europe have shown that lasers can be used to create tiny water droplets when they are fired into the air. The idea could eventually develop into an alternative to cloud seeding as a way of stimulating rainfall.
Physicist Jérôme Kasparian from the University of Geneva in Switzerland, and Philipp Rohwetter of the Free University of Berlin, realized it is not really known how effective is the technique of cloud seeding using silver iodide particles as condensation nuclei, and there are also concerns about the environmental effects of injecting silver iodide into high clouds, so they thought lasers might offer a more “environmentally friendly” solution.
Kasparian, Rohwetter and their colleagues reasoned that shooting a laser into the air would ionize oxygen and nitrogen molecules around the laser beam forming a “plasma channel” of ionized molecules, which could then act as condensation nuclei. They had already used plasma channels to modify weather in 2008, when the team fired a high-powered “Teramobile” laser into thunder clouds, which triggered an electric discharge.
To test the rainmaking idea, the researchers used a laboratory cloud chamber and fired short pulses of infrared laser light into the chamber in conditions of low temperature and very high (230%) humidity. A second low-powered laser was used to illuminate the chamber and allow them to observe what was happening, and measure any water droplets produced.
They discovered that after the laser was fired 50 μm droplets formed immediately along the plasma channel, forming a miniature linear cloud, and the drops then coalesced to form larger droplets around 80 μm in diameter during the three seconds after firing. The total volume of condensed water in the chamber was increased by 50% and the cloud could be seen with the naked eye.
The team then tested the laser technique outside, firing the laser into the sky over Berlin on different nights and in conditions of varying humidity. They again used a low-powered laser to measure the condensation produced. The results showed that no droplets formed when the humidity was low, but when it was high the low-power laser measured almost 20 times more back-scattering when the laser was fired than when it was not, which suggested droplets were being formed, although no cloud was visible to the naked eye.
a, Experimental set-up (schematic). b, Measured vertical temperature (blue, right scale) and derived supersaturation profile (red, left scale) in the chamber. Image credit: Nature Photonics, doi:10.1038/nphoton.2010.115
Kasparian said the research still has a long way to go because condensation is only formed on the plasma channel, but their next step is to use the laser in a sweeping motion across the sky to try to induce condensation in a wider area. They will also try to boost the effectiveness by adjusting the laser’s focus, wavelength and pulse duration.
The paper is published online in Nature Photonics.
More information: Laser-induced water condensation in air, Nature Photonics, Published online: 2 May 2010. doi:10.1038/nphoton.2010.115
 楼主| 发表于 2010-7-6 10:49:12 | 显示全部楼层
目前的人工降雨技术一般是在空中播撒碘化银颗粒作为凝结核,促使水蒸气凝结,而一项最新研究显示,可以使用激光将空气分子离子化,使之成为天然的凝结核,从而达到人工降雨的目的。
新一期英国《自然·光子学》杂志刊登报告说,瑞士等国研究人员发明了这种新技术。其原理是向空气中发射一种高能量短脉冲激光,它会使照射路径上的氮气分子和氧气分子离子化。这些离子化的空气分子就成为天然的凝结核,促使水蒸气凝结为水滴。
研究人员向含有水蒸气的实验装置中发射这种激光,可以马上观察到直径约50微米的水滴形成,这些小水滴还会进一步合并为直径约80微米的大水滴。户外实验也显示,在空气湿度较高的情况下,发射这种激光可以促使空气中水滴的形成。
瑞士日内瓦大学研究人员热罗姆·卡斯帕里安介绍说,这一技术目前还处于初级阶段,不能马上用于人工降雨,因为一束激光只能促使其所照射的路径上形成水滴。下一步研究将探索是否能通过用激光扫过天空的方式,促使水滴在更大面积的空气中形成。
还有观点认为,虽然一束激光不能直接用于人工降雨,但可以通过测量它所促使形成的水滴规模来判断空气湿度,从而帮助降雨预测。
 楼主| 发表于 2010-7-6 10:51:44 | 显示全部楼层
Firing a high-powered laser through an atmospheric cloud chamber containing saturated air.
发表于 2010-7-11 13:07:54 | 显示全部楼层
非常好的研究啊,为激光应用开辟了新方向。
