查看: 2763|回复: 0
[资料] Laser periodically
发表于 2010-7-14 17:26:49 | 显示全部楼层 |阅读模式
In recent years, developments of solid-state lasers pumped by diode laser have attracted much attention because of their wide potential for various applications of compact, long-lived, and ecient sources of coherent radiation. Optical disk systems require green light sources to realize high-density recording. Frequency conversion of laser-diode pumped all solid-state lasers with periodically polednon-linear crystals (such as LiNbO3 [1], LiTaO3 [2], KTiOPO4 [3], KTiOAsO4 [4] andRbTiOAsO4 [5]) into the visible andUV spectral regions is a widely investigatedresearch eld. The quasi-phase-matching frequency-doubler of periodically poled crystals permits access to the highest nonlinear coecient, which is the d33 coecient in the crystals mentionedabove, andavoids any walk-o_ problems because parallel polarizations along the main crystal-axis are used.
Laser periodically.pdf (129.92 KB, 下载次数: 5)
北京中科紫玉光电技术有限公司
地址:北京市海淀区上地东路上地佳园23号楼706室
电话:010-57131375  010-57131377
传真:010-62976020
129.92 KB, 下载次数: 3, 下载积分: 光电贝 -10 元
