2003-3-26 02:18:00 | 显示全部楼层 | 阅读模式
请教各位论坛高手![upload=zip]non-cgi/usr/20/20_126.zip[/upload]
4234查看3回复
2003-3-26 15:20:00
如何在oslo中生成一面为平面(带有倾斜角)一面为球面的透镜。
把surface data spreadsheet - SPECIAL - Coordinates (C)下的各个参数意义搞清楚,你的问题就解决了。
2003-3-26 16:49:00
改了坐标,有2D图像,并可以分析成像等都没有问题。但是无法形成一个成型的透镜,在画出透镜元件机械iso图样时,出错,同样也无法生成3D图像。请教斑竹和高手们!
2003-3-26 17:08:00
你研读下面的数据就可以明白了。
LEN NEW Cherry Hill Catadioptric System 74.986 20
EBR 12.5
OBH -25.0
DES OSLO
UNI 1.0
SNO1 Reversible lens having best performance in 1985 ILDC contest. It is a good
SNO2 example for sign conventions and pickups in complex systems involving mirrors.
SNO3 Note that the prism aperture is round. To make it square, you can define
SNO4 special apertures, turn surface drawing off for each surface, and draw the
SNO5 square vertices using bdi information (see pentprsm.len for an example).
SNO10 PRISM
// SRF 0
AIR
TH  112.5
AP 25.0
NXT // SRF 1
AIR
TH  0.01
NOT The contest rules stated that the stop and image had to be outside the lens.
NXT // SRF 2
GLA BK7
LMO ELE
RD  87.69109102159
TH  8.0
AP 20.0
NXT // SRF 3
GLA SF6
RD  -55.6814740121
TH  30.0
PK AP -1
NXT // SRF 4
AIR
LME
RD  -220.8055680452
TH  1.0
PK AP -2
NOT Entry dblt
NXT // SRF 5
GLA BK7
TH  60.0
AP 30.0
NXT // SRF 6
AIR
TH  2.0
PK AP -1
NOT Prism fwd
NXT // SRF 7
GLA SF6
LMO EGR
RD  -327.3830921607
TH  18.0
AP 35.0
NXT // SRF 8
AIR
RD  -76.08981397546
TH  3.0
PK AP -1
NXT // SRF 9
GLA BK7
RD  -63.47978601779
TH  6.0
AP 35.0
NXT // SRF 10
RFL
RD  -208.7130231955
PK THM -1 0.0
PK AP -1
NXT // SRF 11
PK GLA -3
PK CV  -2 0.0
PK THM -3 0.0
PK AP -2
NXT // SRF 12
PK GLA -5
PK CV  -4 0.0
PK THM -5 0.0
PK AP -4
NXT // SRF 13
PK GLA -7
LME
PK CV  -6 0.0
PK THM -7 0.0
PK AP -6
NOT Objective
NXT // SRF 14
PK GLA -9
LMO ELE
TH  -30.0
PK AP -8
NXT // SRF 15
RFL
TH  30.0
AP 42.4264068711929
DT  1
TLA -45.0
BEN
APN 1
AY1 A -42.4264068711929
AY2 A 42.4264068711929
AX1 A -30.0
AX2 A 30.0
ATP A 1
AAC A 4
NXT // SRF 16
AIR
LME
PK TH  -12 0.0
PK AP -11
DRW OFF
NOT Prism back
NXT // SRF 17
PK GLA -14
LMO ELE
PK CVM -13 0.0
PK TH  -14 0.0
AP 20.0
NXT // SRF 18
PK GLA -16
PK CVM -15 0.0
PK TH  -16 0.0
PK AP -15
NXT // SRF 19
PK GLA -18
LME
PK CVM -17 0.0
PK TH  -18 0.0
PK AP -17
NOT Exit dblt
NXT // SRF 20
AIR
CBK 1
GPRT On
WV 0.588
WW 1.0
END 20
DLNR 1 3
DLFP 1 1.0
DLMN 1 -1.0
DLMX 1 1.0
DLFP 2 -1.0
