2010-9-6 17:35:41 | 显示全部楼层 | 阅读模式
产品名称:C&L波段可调谐激光
所属类别:通讯波段可调谐激光器
厂家名称:美国Terahertz Technologies Inc 公司
产品简介:
通讯波段可调谐激光器
美国The Terahertz Technologies公司 FTE-600高性价比手持式可调谐激光器可提供C波段(1530nm-1565nm)及L波段(156nm - 1625nm)的可调谐激光输出。它显示面板上可以显示波长,频率及ITU channel。FTE-600可调谐激光器和FTE-8000光谱分析仪配合使用,可轻松的对DWDM网络进行的安装调试及检测等操作。客户还可以通过软件对FTE-600可调谐激光器进行远程控制。FTE-600可调谐激光器只需很短的预热时间就可以达到很高的功率稳定性及波长稳定性。FTE-600可调谐激光器是目前市场上少有的性价比极高的通讯波段可调谐激光器。
首页  |  公司简介  |  产品信息  |  技术资料  |  新闻中心  |  代理品牌  |  联系我们
• Selectable Step Size Down to 50 GHz
• Selectable Start & Stop Channels
• Settable in Wavelength or Frequency
• Settable Dwell Time
• Available in C or L Band
• Sealed Rugged Case with Impact Resistant Boot
• USB PC Interface with Remote operation Capability
• Battery Operated or International Line Voltage
• Simple Operation with On-Line Help Mode
• Lowest Cost Hand Held Tunable Laser Source
• Fast Turn-On
• 4” Color Display
Frequency Range FTE-6000 C 192 - 196 THz (1529-1563nm)
FTE-6000 L 187 - 191 THz (1569-1607nm)
Accuracy 1.5 GHz
Line Width 1 MHz
Side Mode Suppression Ration 45 dB
Output Power Range +8 dBm to +14 dBm (C Band)
+5 dBm to +11 dBm (L Band)
Power Setting Resolution 0.01 dB
Power Stability 0.5 dB
Minimum Channel Spacing 50 GHz (0.4nm)
Fiber Type 9/125 μm
Relative Intensity Noise -140 dB/Hz
Graphical Display 4 in Color TFT
Dimensions 7.75 x 4.5 x 2.25 inches
Weight 2 lbs
Battery Rechargeable NiMH - 4 hours operating time
Power 100-240 universal US, GB, EU, AU Mains
Environmental Operation -10°C to + 40°C
Accessories Included Universal power supply with mains for US, UK, CE and AU. Interchangeable FC and SC adaptors, Windows TM Compatible Software, USB Cable, Manual and Rubber Boot
FTE-6000C C-Band Tuneable Laser Source
FTE-6000L L-Band Tuneable Laser Source
FTE-8600C C-Band Tuneable Laser Source with C Band Optical Spectrum Analyzer
FTE-8600L L-Band Tuneable Laser Source with L Band Optical Spectrum Analyzer
关键字:可调谐激光器,通讯波段可调谐激光器,C&L波段可调谐激光器,C波段可调谐激光器,L波段可调谐激光器,高性价比可调谐激光器
如需进一步信息,请联系关于美国Terahertz Technologies Inc (TTI)公司的指定代理商 昊量光电
上海昊量光电设备有限公司
  电话:+86-21-51083793,62578098
  传真:+86-21-52664077
  E-Mail: info@haoliangtech.com
  website:www.haoliangtech.com
  官方博客: blog.sina.com.cn/auniontech
  地址:上海市中山北路2668号联合大厦1311室
  邮编:200063
