查看: 1865|回复: 0
[供应] 光纤损耗测量仪
发表于 2010-9-6 17:38:17 | 显示全部楼层 |阅读模式
产品名称:HPT- 5100双向光纤损耗测试
所属类别:光纤损耗测量
厂家名称:美国Terahertz Technologies Inc 公司
产品简介:
美国Terahertz Technologies Inc 公司(TTI公司)HPT- 5100是一台真正意义上的双向光纤损耗测试仪,HPT- 5100双向光纤损耗测试仪可以对单根光纤进行实时的双向损耗测量(1310 & 1550 nm)。HPT- 5100双向光纤损耗测试仪还可以被用作光功率计,其动态范围从 +25dBm 到 - 60 dBm. HPT- 5100 双向光纤损耗测试仪在出厂前均已对850, 1300, 1310, 1490, 1550,1625nm波长进行了校准。为了提高测量效率,HPT- 5100双向光纤损耗测试仪在子机与母机之间通过文本信息通讯。这使得分别在光纤两端的工人能够快速而便捷的通信在 。HPT- 5100双向光纤损耗测试仪内置的记忆体可以储存1000条以上的记录. 更为重要的是HPT- 5100双向光纤损耗测试仪是目前市场上同类型产品中性价比最高的双向光纤损耗测试仪。
特点:
● Real time display of Dual Wavelength Loss and ORL
● Automated dual wavelength loss and ORL measurements
● Bi-directional measurements using a single fi ber
● Built in fi ber identifi er
● Text Messaging Communications
● Computer and Printer interface
● Q VGA Graphic Display
● Display Backlighting
● Rugged, Watertight Case
● Storage for 1000 records
● Free PC application software
● Rechargeable NiMH batteries , 16 Hours / charge
指标参数
Loss Measurement Dynamic Range  0 - 45 dB in Hypertest Mode, 60 dB in Manual Mode
Loss Measurement Wavelengths  1310, 1550 nm, ?20 nm
Units of Measurement  dBm, dB, 0.01 dB resolution
Measurement Rate  Four updates per second
Inter-unit Communications  Text, eight standard messages provided, Transmitted via Fiber-Under-Test
Hypertest Displayed Quantities  Loss A-B, Loss B-A, ORL from A, ORL from B, Each value @ 1310 and 1550 nm
Laser Safety Classification.  Class I safety per FDA/CDRH and IEC-825-1 regulations
Laser Output Power  0 dBm, 1 mw
Laser Output Stability  ?0.1 dB for 1 hour
Laser Linewidth  < 5 nm
Optical Return Loss Dynamic Range  0 - 65 dB
Optical Return Loss Accuracy  ?0.5 dB @ a -55 dB reflection
Power Meter Detector  InGaAs, 2 mm diameter with universal 2.5 mm ferrule adaptor
Calibrated Wavelengths Provided  850, 1300, 1310, 1490, 1550, 1625 nm
Modulation Modes Provided, (transmit and detect)  CW, 270 Hz, 1000 Hz, 2000 Hz
Power Meter Accuracy  ?0.18 dB under reference conditions, ?0.3 dB +20 to - 50 dBm
Power Meter Display  .01 dB resolution, unit of dBm or dB
Memory Storage Locations  1000
Display  4 ?QVGA LCD Graphic Display with Electroluminescent Back light
Standard Optical Connector Interface  FC/APC, (other types available or request)
Batteries Supplied  Rechargeable NiMH AA cells, eight
Operating Time  Approximately 16 hours following a full charge
Power Supply / Charger Provided  Wall Mount, 120 VAC, 50 -60 Hz, or 220 VAC 50-60 Hz, Specify
Power Requirements  10 VA Max
Temperature Range  0 to 50 C Operating,, -20 to 60 C Storage
Dimensions (L x W x D)  8.1?x 6.4?x 3.5? 210 x 160 x 90 mm
Weight  2.8 lbs, 1.3 Kg
Accessories Provided  Batteries, Power supply/charger, manual, Rs-232 Cable, PC application software
Standard Warranty  Two years, Components and Workmanship, 30 Day Satisfaction Guarantee
产品名称:LTS-1500自动光纤损耗测试仪
所属类别:光纤损耗测量仪
产品简介:
美国Terahertz Technologies Inc 公司(TTI公司)LTS-1500自动光纤损耗测试仪是一种小型、坚固的自动化光纤损耗测试仪器,可以对850、1300、1310、1490、1550nm波长连接单模和多模光纤进行测试,它由一个灵敏的InGaAs光功率计及一个稳定激光源构成,光功率计以6个波长校准,噪声水平优于-75dBm,激光源有多达3个可选波长。
LTS-1500自动光纤损耗测试仪在自动测试模式下, 主单元以固定比率改变波长,并且通知副单元当前测量的波长。损耗测量保存每个波长损失到内存中。通过USB端口或前面板,多到2000个三波长测量可储存和调出。提供的应用软件可下载存储的数据并组织分析这些数据信息。用270,1000及2000HZ调制频率,该设备也可以进行光纤识别。
LTS-1500自动光纤损耗测试仪由锂电池供电,锂电池可以提供超过15个小时的连续工作时间,同时在紧要时刻,任何9V的碱性电池也可以被替换使用。
LTS-1500自动光纤损耗测试仪标准配件包括橡胶防护底和支架,USB线,FC/ST/SC的连接适配器,通用电源充电器,应用程序CD和操作手册。
特性
自动波长调节
通用功率计和光源适配器接口 FC/ST/SC
-75dBm动态范围的功率计
3波长的单输出激光源
可存储2000个三波长损耗检测数据
可充电的9V锂电池
USB接口
免费Windows系统兼容报表软件
LTS-1500 Specifications
Power Meter Detector Type
InGaAs
Dynamic Range
+5 to -77 dB
dBm, dB,
Resolution
0.01dB
Power Input Range
+5 dBm to - 77 dBm
Power Measurement Uncertainty
± 0.18 dB under reference conditions, ± 0.25 dB from 0 to -65 dBm, ± 0.35 dB from 0 to +5 dBm and from -65 to -77 dBm
Laser Output Power
0 dBm, 1mw
Output Stability
± .05 dB / 24 hrs @ constant temp,, ± .02 dB/C temperature coeffi cient
Laser Wavelengths Provided
850nm, 1 300nm, 1310 nm , 1490, 1550 (± 20 nm)
Modulation Modes
Laser Safety Classifi cation
Autotest Range
0 to - 36 dB
Display
LCD, power reading, 0.4” high digits, .01 dB resolution Power meter, laser wavelength display 0.16” high digits
Annunciators
Fiber ID, - 3, modulation mode - 4, Autotest - 2, Lo Bat, Auto Off
Storage Locations
2000
Battery/Operating Time
Rechargeable Li Polymer/Approximately fi fteen hours following a full charge
Universal, US, UK, Continental Europe, and Australian Plugs Included
Power Requirements
95-260 VAC, 50-60 Hz, 3 VA Max
Operating Temperature Range
-10 to 45 C
Dimensions (with rubber boot )
5.9” L x 3.9” W x 1.37” H (150mm L x 100mm W x 35mm H)
Weight
0.52 Kg
FC, ST, SC adaptors for both Power Meter and Light Source, rubber boot, battery, Power supply/Charger, manual , USB Cable, PC application software
LTS-1500 Ordering Information
LTS-1500-813
Loss Test Set with 850/1300nm Light Source
LTS-1500-3
Loss Test Set with 1310nm Light Source
LTS-1500-5
Loss Test Set with 1550nm Light Source
LTS-1500-35
Loss Test Set with 1310/1550nm Light Source
LTS-1500-345
Loss Test Set with 1310/1490/1550nm Light Source
产品名称:光纤损耗测量用功率计和光源
所属类别:光纤损耗测量仪
产品简介:
美国Terahertz Technologies Inc 公司(TTI公司)1500系列光纤损耗测量用功率计和光源, 是小巧坚固,拥有单/双/三波长的,自动化光纤光功率计和光源。功率计由一个敏感的InGaAs探测器组成,由6个波长进行校正,并且拥有75dB的动态范围。
当PM-1500功率计和LS-1500-X光源一起使用的时候,它们可以在自动检测模式下进行操作,这时光源会以固定的频率改变波长并且通知功率计当前被测量的波长。通过USB口和面板操作,多到2000个三波长测量数据可以被储存和调出。提供的Windows兼容软件可以用来下载存储的数据和打印专业报表。
光源设备可选择工作在定波还是调制波。功率计通过LS-1500-X的调制模式或者用其他的270/1000/2000HZ调制频率的光源可以对光纤进行分辨。
配置可充电的锂电池,同时也可以用一般的9V碱性电池进行跟换以备急用。
功率计和光源配(同时购买)有一个工作箱,保护橡胶底座和支架,FC/ST/SC连接器,通用电源适配器,操作手册。功率计还提供软件CD和USB连接线。所有功率计和光源有一个两年,零部件维修保证
1500 Series Specifications
Power Meter Specifications
InGaAs
dBm, dB,
Resolution
0.01dB
Power Input Range
+5 dBm to - 77 dBm (CATV +25 dBm to -57dBm)
Autotest Measurement Rate
Four seconds per wavelength
Autotest Range
0 to - 36 dB
Storage Locations
2000
Rechargeable Li Polymer/Approximately twenty hours following a full charge
Power Requirements
-10 to 45 C
Storage Temerature Range
Equipment -10 to 60C,         Battery 0-40C
5.9” L x 3.9” W x 1 .37” H      (150mm L x 100mm W x 35mm H)
Weight
0.52 Kg
FC, ST, SC adaptors, rubber boot, battery, power supply/charger, manual, USB Cable, PC application. Software
Light Source Specifications
Laser Output Power
0 dBm, 1 mw
Output Stability
850nm, 1300nm, 1310 nm ± 20 nm, 1490 ± 20 nm, 1550 ± 20 nm
Spectral Width
< 3nm typ.
Modulation Modes
Laser Safety Classifi cation.
Battery
Operating Time
Universal, US, UK. Continental Europe, and Australian Plugs Included
Power Requirements
-0 to 40 C
Weight
0.52 Kg
FC, ST, SC adaptors, rubber boot, battery, power supply/Charger, manual
订购信息
Singlemode power meter
PM-1 500 Power Meter
PM-1500C CATV Power Meter
Singlemode Light Sources
LS-1500-3 1310nm Singlemode Light Source
LS-1500-4 1490nm Singlemode Light Source
LS-1500-5 1550nm Singlemode Light Source
如需进一步信息,请联系关于美国Terahertz Technologies Inc (TTI)公司的指定代理商 昊量光电
