查看: 1747|回复: 0
[供应] 片剂四用测定仪
发表于 2010-9-15 11:00:06 | 显示全部楼层 |阅读模式
78X-6A片剂四用测定仪
78X-6A型片剂四用测定仪是我公司在原78X-2型片剂四用测定仪基础上创新设计的产品,该产品技术指标均符合《中国药典2005年》版规定。是比较理想的药检测试仪器。
二、 主要技术规格
崩解部分:
吊篮上下移动距离                        55±2mm
吊篮上下往复次数                       30~32次/分
平底烧杯容积                            1000ml
平底烧杯数量:                          2只
杯内水温                                37± 0.3 ℃
吊篮上升篮网至液面距离                  25mm
吊篮下降篮网至杯底距离                  25mm
2.        溶出部分:
转速                                   25~200r.p.m
转速精度        ±1%转
篮旋转摆动幅度                        ≤±1mm
浆叶旋转摆动幅度                        ≤±1mm
球底烧杯容积                            1000ml
球底烧杯数量                            6只
3.脆碎部分:
轮鼓直径:                           Ø286±0.20mm
轮鼓深:                             39±0.30mm
轮鼓数量:                           2只
转速:                               25转/分、100转停机
4.        硬度部分
被测药片最大直径                       25mm
最大测试压力                           200N
测试精度                               5N
78X-6A four functions tablet tester is a new innovate designed production which is based on former model 78X-2 four functions tablet tester. All the tester technical indicators are in line with the "Chinese Pharmacopoeia 2005" version of the provision. It is an ideal drug testing equipment.
78X Series tablet tester is the best testing equipment for research units, universities, drug checking department and pharmaceutical company.
78X-2B片剂四用测定仪
78X-2B型片剂四用测定仪,是我公司开发的新产品,该仪器集药物片剂的硬度,脆碎度,溶出度和崩解度四种功能于一体.整机结构设计合理,性能稳定,操作方便,测试数据精确可靠,主要技术指标符合《中国药典2005版》的规定,广泛用于医药行业的科研,教学,药检所及各制药行业的质量管理部门和实验室.
二、 主要技术规格
崩解部分:
吊篮上下移动距离                        55±2mm
吊篮上下往复次数                       30~32次/分
平底烧杯容积                            1000ml
平底烧杯数量:                          2只
杯内水温                                37± 0.3 ℃
吊篮上升篮网至液面距离                  25mm
吊篮下降篮网至杯底距离                  25mm
溶出部分:
转速                      50、100、150、200r.p.m
转速精度        ±1%
转篮旋转摆动幅度                        ≤±1mm
浆叶旋转摆动幅度                        ≤±1mm
球底烧杯容积                            1000ml
脆碎部分:
轮鼓直径:                           Ø286±0.20mm
轮鼓深:                             39±0.30mm
轮鼓数量:                           2只
转速:                               25转/分、100转停机
环境温度:                           1~35℃
环境相对湿度:                       ﹤85%
硬度部分
被测药片最大直径                       25mm
最大测试压力                           200N
测试精度                               5N
78X-2B four functions tablet tester is a new innovate designed production which have four functions including test tablet’s hardness, friability, dissolution and disintegration. The tester structure designed with reason, performance with stability, easy to operate, test data with reliable and accurate. All the tester technical indicators are in line with the "Chinese Pharmacopoeia 2005" version of the provision. the tester is widely used by the pharmaceutical industry from research units, teaching, drug checking institution and quality control department as well as laboratory. The main technical specification        the part of disintegrationDistance Hanging Basket Covers Vertically            55±2mm Times of Hanging Basket Up and Down              30-32 times/min the volume of flat-bottomed beaker                  1000ml the number of flat-bottomed beaker                   2 pieces    the part of dissolutionThe speed of rotation                    50,100,150,200  rpm The accuracy of rotary speed                   ±1% The volume of spherical support beaker          1000 ml    the part of friabilityThe diameter of brake drum                 Ø286mm±0.20mm The depth of brake drum                     39mm±0.30mm The number of brake drum The rotary speed                     25r/min. 100r/min will be stopped    the part of hardnessthe max. Diameter of testing drug                25mm the max. testing pressure                       200N
the testing accuracy                            5N
78X-2片剂四用测定仪
78X-2型片剂四用测定仪曾获上海市技术革新奖,它将药片的多种性能的测试综合在一台仪器上完成,可分别用于药片的硬度、脆碎度、崩解度和溶出度测试,适用与各制药厂车间的初级检测和医学院校的教学实验等。
技术参数:
被测药片最大直径                        16mm
最大测试压力                            200N
测试精度                                10N
恒温精度                                37±0.5℃
