查看: 6660|回复: 3
[讨论] 招聘光电产品工程师
发表于 2010-9-19 14:28:15 | 显示全部楼层 |阅读模式
mail box: amina.huntercareer@gmail.com
SUMMARY OF JOB FUNCTION:
Support manufacturing for high quality and low cost operation.
KEY RESPONSIBILITIES:
- In possession of end to end product knowledge, able to evaluate changes in process, test and material.
- Release and maintain the product BOM and related technical documents.
- Drive the product yield improvement activities to meet the production target and product lifecycle criteria.
- Responsible for investigating the RMA and write report.
- Drive the cost reduction and quality improvement for the responsible products.
- Manage the product lifecycle, responsible for writing the related documentations and driving the functional review.
- Understand the detail specification of the product, able to communication with customer on the specification changes.
- Set up manual diagnosis station with proper equipments for product failure analysis and rework.
- Train the technicians to have right skill to do product failure diagnosis and rework.
QUALIFICATIONS:
BSc/BEng/MSc/MEng (or equivalent) in Electronic Engineering/Physics/Optical Communications or similar discipline.
KNOWLEDGE/SKILLS:
- 3+ years experience in working on active components and modules. Working experience of XFP, SFP or Transponder is preferable.
- Deep understanding of optical passive and active components/modules and performance.
- Solid knowledge of fibre communication components/modules test and measurement, result analysis.
- Good knowledge of the digital and analog electronic circuit and systems.
- Good knowledge of Optical Communication systems.
- Solid skills in leading product introduction to manufacture.
- Solid skills in product failure analysis and data analysis.
- Experience of project management is preferable.
EXPERIENCE:
Working experience in an optic_electronic environment is preferable
Broad technical background, particularly in telecommunications, electronics, optics and semiconductors. Experience with RF design and RF components tests is preferable.
Experience and knowledge of optical components, fibre-optic communications systems
发表于 2010-10-5 20:12:25 | 显示全部楼层
看不懂啊。楼主翻译下给我吧。
发表于 2010-10-6 19:40:53 | 显示全部楼层
工作地点在什么地方?
发表于 2010-10-6 21:21:07 | 显示全部楼层
工资待遇什么的,工作地点怎么都没提呀,楼主能不能详细点儿。。。。。。。。。。。。。。。。。。呵呵
