西安聚星提供单纵模蓝光473nm激光器,请大家参考。 473 nm Blue Laser Specifications (download)
Wavelength 473 nm
CW output, mW 150, 100, 75, 40, 25, 10, 5; Noise <3%(1Hz-5kHz)
Low noise output 15, 10, 5 mW; Noise <1%(1Hz-10MHz)
Transverse mode TEMoo, M2<1.2
Beam diameter (1/e2) 0.25mm
Beam divergence 3mrad
Output stability, rms <2% over 8 hrs; Ultra-stable option: <0.25% over 24 hrs
Beam point stability +/-0.005 mrad/K
Polarization ratio > 50 : 1
Longitudinal mode 2-4 longitudinal modes
SLM available Single longitudinal mode with >100m coherence length
Spectrum linewidth 0.1 nm, nominal; SLM version: < 10-5 nm
Operating temperature 10 to 35 degree C
Operating voltage 90-250 VAC or 9-20 VDC
Warm-up time 1 minute
Power consumption 15 W
Size of laser head 3 x 3 x 12 cm with a fixed 6 mm thick base plate
Size of power supply AC: 5x14x15 cm (2x5x6 inch) DC: 3.5x8.5x12.7 cm
