查看: 1714|回复: 0
[需求] 采购200片抛光片、一台绝缘测试仪!
发表于 2010-11-25 16:44:28 | 显示全部楼层 |阅读模式
各位好,本公司位于厦门,是一家刚成立的从事多晶硅太阳电池片生产的公司。
采购200片抛光片、一台绝缘测试仪!
一、抛光片的规格如下:
p-type Si:B [100] 6" 625um P/E SSP 0—100ohm-cm Test Grade with flat.
二、绝缘测试仪的规格参考如下:
Samples to be measured        1、Mono- and multi-crystalline wafers
                                                2、Square or pseudo square
                                                3、Textured or non-textured surface
                                               4、Diffused layer (n+p or p+n)
                                               5、Wafers without contacts, cells with contacts
                                               6、Edge-isolated
Wafer size                                      100 … 156 mm
Measurements                     Testing of edge isolation resistance by 2-point probing
Sample preparation                    Wafers after diffusion and edge isolation
measured area                    Whole wafer
Measurement time                    App. 5 sec. per wafer
System dimensions
(W x H x D)                   220mm x 150mm x 300mm (ISO-TEST unit)
                                           90mm x 50mm x 110mm (Multimeter)
                                            200mm x 30mm x 110mm (Switch)
如果大家有意向,或者有疑问,或有建议,可及时和我联系。邮箱是douglas.dou@xiamensona.com,谢谢。
