查看: 3044|回复: 1
请问哪儿有法布里-珀罗标准具(F-P Etalon)?
发表于 2003-10-20 20:35:00 | 显示全部楼层 |阅读模式
规格如下:
Solid etalon
Free Spectral Range 29.4 +/- 1.0 Ghz
Finesse 29
Wavelength 650nm
Material Fused Silica
Diameter 25.4 +0.0/-0.2 mm
Thickness 5.0 +/- 0.1 mm
Clear Aperture 22mm
Wavefront Distortion lambda/10 @ 650nm
Surface Quality 10/5
Parallelism 1 arcsec
Coated for R = 90% @ 650 nm
请回Email到: jiangjinb@163.net
发表于 2003-10-24 05:15:00 | 显示全部楼层
JDSU好像有吧,以前华科作这个很拿手
