查看: 2282|回复: 10
[供应] 提供激光二极管
发表于 2010-12-1 15:49:12 | 显示全部楼层 |阅读模式
西安聚星代理美国RPMC厂家的激光二极管:
Multimode Single Emitters
622nm - 1850nm Laser Diodes (76)
LDX Optronics was incorporated in 1990 and is focused on broad stripe multimode laser diodes largely in the esoteric wavelengths with an emphasis on the red laser diodes modules and Infrared wavelengths. LDX offers the widest wavelength range in the industry, with wavelengths available from 622nm - 1.8um. Packages available; 9mm, T0-18, T0-3, HHL, Butterfly, and Fiber coupled.
LDX-FC Series Fiber Coupled Laser Diodes - Multi Emitter
This fiber coupled laser diode module can use any of the LDX Optronics 100um emitter devices, which makes this a very flexible module. Available wavelengths range from 630nm to 1850nm. Multiple emitters (2, 3 and 4 emitters) can be used in a single package to develop output powers of several 100mW to 10,000mW or more.
Single Mode Free Space Laser Diodes (405nm - 1550nm) (114)
RPMC offers a complete line up of single mode red laser diodes and infrared laser diodes. Wavelengths range from 405nm to 1550nm.
Single Mode Fiber Coupled Laser Diodes (405nm - 1610nm) (69)
RPMC offers a complete line up of single mode red laser diodes and infrared laser diodes. Wavelengths range from 405nm to 1610nm.
Short Pulsed Laser Diodes
SLD Modules (22)
These OEM Super luminescent Laser Diode Modules are an ideal building block for system integrators especially for fiber optic sensing and optical tomography applications. It requires only a single +5V power supply with low power consumption.
SLD Benchtop Modules (36)
These OEM Super luminescent Laser Diode Benchtop units incorporate a user-friendly front panel housing a LCD monitor display, key switch, power adjust control knob and optical connectors. A RS232 computer interface is also equipped on the rear panel. 1 MHz intensity modulation is available as an option.
   SLD Multi-Band Modules (10)
These Multi-Band SLEDs are high power, stable, incoherent broadband sources. They cover very large spectral widths with very small spectral ripples. Applications include component characterization, return loss measurement, and optical sensing.
Superluminescent Diodes (42)
  Fabry-Perot Laser Diodes
Distributed Feedback (DFB) Laser Diodes
Unmounted Bars
Jenoptik - Epitaxial wafers, high quality production, world leading device efficiencies, extremely high reliability, low divergence. Single emitters up to 8W, laser diode bars with power levels up to 120W CW and 300W QCW. Wavelengths available from 790nm to 1064nm.
   High Power Conductive Packages
Jenoptik -World leading power level passivly cooled devices, low thermal resistance, high tempature operation, CW power levels up to 120W, & QCW up to 300W. Devices available with collimation of the fast and slow axises. All bars are available in either a CS, S or the NEW CN mount. Wavelengths available from 795nm to 1064nm.
   High Power Laser Diode Stacks
Di-water cooled stacks available from 1 to 25 bars. High reliability, life times greater than 10,000 hour, power levels up to 3000W CW. Many different package configurations available. CW power levels up to 120W, & QCW up to 300W per bar. Devices available with collimation of the fast and slow axises. Wavelengths available from 790nm to 1064nm.
   QCW Bars and Stacks
Single bars packages, micro-channel cooled arrays as well as space qualified G package type stacks. Power levels up to 300W per bar at a 1% duty cycle and 150W at a 10% duty cycle. Wavelengths available from 808nm to 980nm.
 楼主| 发表于 2010-12-1 15:51:34 | 显示全部楼层
如果您对我们的产品感兴趣,请致电西安聚星光电技术有限公司。
联系人:贾洁,手机:15802915003,邮箱:jiajie@fy-ic.com
发表于 2010-12-2 10:28:40 | 显示全部楼层
你好,请问你们那有没有1650nm的管子,我们主要想做气体分析用,5-10mW就行~
发表于 2010-12-2 11:53:16 | 显示全部楼层
西安聚星光电技术有限公司
联系电话:029-88229607 88229186
传    真:029-88227252
网    址:http://www.gatherstar.com
          http://www.gatherphoton.com
地    址:陕西省西安市电子一路18号软件公寓C座1807室
发表于 2010-12-3 16:07:08 | 显示全部楼层
西安聚星光电技术有限公司
传    真:029-88227252
发表于 2010-12-6 13:51:08 | 显示全部楼层
好贴,波段覆盖比较广O(∩_∩)O哈哈~
发表于 2010-12-6 15:49:27 | 显示全部楼层
求购激光二极管www.prolaserb2b.com
 楼主| 发表于 2010-12-7 16:42:16 | 显示全部楼层
1650nm
型号:FYM-RLT1650M-7G
    参数:1650nm,7mw,
chip size:1*200um,
Package:9mm
您看能不能满足您要求。希望您留下联系方式,咱们具体沟通。
 楼主| 发表于 2010-12-28 11:35:36 | 显示全部楼层
恭祝:元旦快乐
发表于 2010-12-29 15:49:47 | 显示全部楼层
祝大家元旦快乐~
 楼主| 发表于 2010-12-30 14:54:24 | 显示全部楼层
西安聚星光电技术有限公司
MOBILE:15802915003
TEL:029-88248233-8037
FAX:029-88227252
地址:西安市电子一路18号西部电子商城软件公寓C座1807室
Web:  http://www.gatherstar.com
聚星公司代理光电产品:
探测器产品线
1.美国Judson:红外探测器及其附件产品,专业制造HgCdTe、Ge、InSb、PbS、PbSe、InAs、InGaAs探测器。
2.美国EOS:探测器\光电元件,探测器组件,自订仪器,涵盖完整的紫外、可见——40微米光谱区域。
3.波兰Vigo:中、长波,非制冷红外光电探测器及其附件,制冷光电探测器。
4.德国IFW:SIC紫外探测器,200-400nm或210-380nm。
5.台湾CLPT:共焦平面InGaAs阵列。
激光器产品线:
1.美国Crystalaser全固态激光器。
2.美国Apollo高功率半导体激光器。
3.德国Impex固体激光器。
4.A系列激光二极管:785-1064nm。
5.R系列激光二极管:405-1064nm。
成像产品:红外热像仪、红外热像机芯。(制冷和非制冷)
附件产品:美国MAC二氧化碳功率计、光谱仪、热成像板。
