查看: 1670|回复: 0
[供应] LED365大功率产品
发表于 2010-12-7 22:59:33 | 显示全部楼层 |阅读模式
L365C-D0102 is an AlGaAs LED mounted on copper heat sink molded with epoxy lens .
On forward bias, it emits a band of radiation which peaks 365nm.
u Specifications Outer dimension (Unit: mm)
1>Product Name High Power Top LED
2>Type No. L365C-D0102
3>Chip
Chip Material AlGaAs
Peak Wavelength 365nm typ.
4>Package
(1)Type Super Beam type LED
(2)Resin Material Epoxy Resin or silicon
(3)Lead Frame Silver Plated Copper
(4)Insulator Ceramic
u Absolute Maximum Ratings
Item Symbol Maximum Rated Value Unit Temperature
Power Dissipation PD 1000 mW Ta=25℃
Forward Current IF 500 mA Ta=25℃
Reverse Voltage VR 10 V Ta=25℃
Operating Temperature TOPR -30 ~ +85 ℃
Storage Temperature TSTG -30 ~ +100 ℃
Soldering Temperature TSOL 265 ℃
#Pulse Forward Current condition: Duty=1% and Pulse Width=10us.
#Soldering condition: Soldering condition must be completed within 3 seconds at 265℃。
u Electro-Optical Characteristics[Ta=25℃]
Item Symbol Condition Minimum Typical Maximum Unit
Forward Voltage VF
IF=10mA 1.2 V
IF=350mA 3.3 3.6 V
Reverse Current IR VR=10V 5 uA
Total Radiated Power Po IF=350mA 85 mW
Peak Wavelength λp IF=350mA 360 365 370 nm
Half Width Δλ IF=350mA 10 nm
Viewing Half Angle Θ1/2 IF=350mA ±60 deg
有需要些产品联系:杨小姐0755-86173841/18818798007/13410328007/YHJ712123@126.COM
