查看: 1279|回复: 0
[供应] 光电传感器/发射及接收管
发表于 2010-12-8 19:22:02 | 显示全部楼层 |阅读模式
Emitters发射器
一:红外发光二极管(砷化镓)
Type No.        MAXMUM RATINGS                                ELECTRO-OPTICAL CHARACTERISTICS
        Forward        Reverse        Power        Operating        Radiant intensity                Forward voltage                Peak emission        Half angle
        current        voltage        dissipation        temp.        PO[mW/sr]                VF[V]                wavelength        ΔΘ[deg.]
        IF[mA]        VR[V]        PD[mW]        Topr.[ °C]                                        λp[nm]
                                        Typ.        IF[mA]        Max.        IF[mA]        Typ.        Typ.
EL-1CL3        60        4        80        -20~+70        1.8        40        1.5        40        940        ±53
EL-1K3        100        5        200        -40~+100        4.0mW        100        1.7        100        940        ±36
EL-1KL3        100        5        170        -30~+100        15        100        1.7        100        940        ±36
EL-1KL5        100        5        200        -40~+100        10        100        1.7        100        940        ±5
EL-1ML2        100        5        170        -25~+70        6.5mW        50        1.5        50        940        ±32
EL-23G        60        5        100        -20~+100        2        60        1.6        60        940        ±30
EL302        50        5        75        -25~+85        0.7        50        1.6        50        940        ±30
EL305        50        5        75        -25~+85        1        20        1.5        20        940        ±20
KEL314        50        5        75        -25~+85        0.7        50        1.6        50        940        ±30
KET511        50        5        75        -20~+85        -        -        1.5        20        940        ±40
EL325        50        5        100        -25~+85        0.7        50        1.6        50        940        ±60
EL333        50        5        75        -25~+85        1.8        20        1.5        50        940        ±20
KEL55L        50        5        75        -25~+85        2        20        1.5        50        940        -
EL6F11        50        4        80        -25~+85        6        50        1.65        50        940        ±25
KEL1001L        50        5        100        +25~+85        5        20        2        20        940        ±10
KEL-209A        100        5        160        -20~+80        11        50        1.6        20        940        ±90
KEL3001A        50        5        75        -25~+85        17        50        1.7        50        940        ±20
KEL3002A        50        5        70        -25~+85        20        50        1.4        50        940        ±20
二:红外发光二极管(镓铝砷)
        current        voltage        dissipation        temp.        PO[mW]                VF[V]                wavelength        Δθ[deg.]
        IF[mA]        VR[V]        PD[mW]        Topr.[°C]                                        λp[nm]
AL-402        100        5        150        -25~+70        2.2        50        2        50        910        Max.12
KBL-1KL3        50        5        120        -40~+100        450        20        2.2        20        660        ±8
CL-1CL3        60        4        80        -20~+70        7        40        1.5        40        880        ±53
CL-1KL3        100        5        170        -30~+100        7.5        100        1.7        100        880        ±17
CL-1KL7        100        5        200        -30~+100        8        100        2        100        880        ±8
CL-203        80        5        160        -40~+100        5        50        2        80        880        Max.9
CL-205        80        3        160        -30~+100        10        50        2        50        870        ±9
CL-207        100        5        150        -30~+100        56mV        20        1.6        20        880        ±35
CL-208        80        5        130        -20~+80        35mV        20        1.6        20        880        ±40
CL-209        80        5        130        -20~+80        30mV        20        1.6        20        880        ±85
CL-211        50        4        70        -30~+85        90mV        20        1.6        20        870        ±12
CL-304L        50        5        100        -25~+85        7.6        50        2        50        880        ±30
KFL-1ML-N        80        5        140        -25~+80        14        50        1.7        50        850        ±63
ML-1CL3        50        3        80        -20~+70        -        -        1.7        50        865        ±53
ML-1K3        50        3        85        -30~+100        -        -        1.7        50        865        ±36
KELD001        50        5        75        -25~+85        0.2        20        2        20        940        ±15
SMLP(Surface Mountable Leadless Package)SMLP(表面贴装无铅封装)
KEM5001R        50        5        95        -25~+85        16        50        1.6        50        870        20
KEL0315C        50        6        75        -20~+85        2.5        20        1.4        20        940        ±15
三:发射器的光纤(镓铝砷)
塑料光纤的基本法型,玻璃纤维660nm为830nm,是佛罗里达州式。 GaA1As既高的树脂模具型高速响应型的。
Type No.        MAXIMUM RATINGS                                ELECTRO-OPTICAL CHARACTERISTICS
KBL23G        40        5        100        -25~+85        1.6        20        2.1        20        660        ±30
四:Pin Point LED(AIGalnP)针点发光二极管(AIGalnP)
该公司的独家技术A1GaInP,双异质结构的光波长发光二极管是一种650nm的红色光。 Φ150㎛ ㆍ Φ150㎛光部门的亮度。镜头射灯使用的光学设计,可以很容易获得,是适合的光电开关。
BL05-1101        20        3        50        -30~+85        0.2        20        3        20        650        ±60
BL05-1211        20        3        50        -30~+85        0.3        20        3        20        650        ±7
BL15-1101        40        3        100        -30~+85        0.4        20        2.8        20        650        ±60
BL15-1212        40        3        100        -30~+85        0.5        20        2.8        20        650        ±18
BL15-325        40        3        100        -20~+85        0.9        20        2.8        20        650        ±40
BL15-6F        40        3        100        -20~+85        1.2        20        2.8        20        650        ±40
五:线型发射器,7dots发光二极管(AIGalnP)
        Forward        Reverse        Operating        Radiant intensity [Average]                Radiant intensity                Forward voltage                Reverse current                Peak emission
        current        voltage        temp.        PO[mcd]1                [deviation]                VF[V]                IR[μA]                wavelength
        IF[mA]        VR[V]        Topr.[°C]                        S[%]                                                λp[nm]
                                Min.        IF[mA]        Min.        IF[mA]        Max.        IF[mA]        Max.        VR[V]        Typ.
LH-7702        1.5        3        -20~+60        0.4        1        ±20        1        2.7        1        100        2        595
LH-7703        10        5        -10~+50        -        -        -        -        2.5        6        10        5        585
LH-7705        1.5        3        -25~+60        0.4        1        ±20        1        2.7        1        100        2        595
