查看: 1538|回复: 0
[供应] Line-up > Photo IC/ICs 发射器IC
发表于 2010-12-8 19:25:30 | 显示全部楼层 |阅读模式
打印机和其它光学ilbangwang干扰常用的电气gwangpikeopyong激光探测器噪声办公设备照片IC传感器,内置的运用,以及没有CD播放机,光盘接送照片集成电路的放大器,keompae插画功能内置的功能和最好的价格和生产正在实现和复位IC。        联系人:杨小姐0755-86173841/1881879800/13410328007/YHJ712123@126.com.msn:yangzhuo712@hotmail.com有需要请联系。谢谢。
一:图片集成电路
        MAXIMUM RATINGS(Ta=25°C)
Type No.
        Supply                Low level                Power                Operating
        voltage                output                dissipation Po[mW]                temp. Topr.[°C]
        Vcc[V]                current
                        IOL[mA]
PIC0103SD        17                30                200                (-25~+85)
PIC0803SD        17                30                200                (-25~+85)
PIC1503SD        10                20                100                (-25~+85)
PIC2503SD        12                30                100                (-25~+90)
Type No.         ELECTRO-OPTICAL CHARACTERISTICS(Ta= 25°C)
        Supply voltage Vcc[V]        High level supply current lCCН[mA]                Low level supply current                L-H threshold illuminance EVLH[lx]        Hysteresis        Peak wavelength
                typ      Ev[Ix]                lCCL[mA]                L→H        EVLH/EVHL        λp[㎚]
                                typ   Ev[Ix]
PIC0103SD        4.5~17.0        3        100        3        0        40        0.8        900
PIC0803SD        4.5~17.0        3        0        3        100        25        0.8        900
PIC1503SD        4.5~5.5        0.9        Ee=0 [mW/cm²]        1.7        Ee=0.5[mW/cm²]        0.03 [mW/cm²]        0.7        900
PIC2503SD        4.5~5.5        1.7        Ee=0.2 [mW/cm²]        1.7        0        0.03 [mW/cm²]        0.7        900
二:Photo AMP摄影放大器
Type No.        MAXIMUM RATINGS(Ta=25 °C)
        Supply                output                Storage temperature range                Operating
        voltage                current                Tstg.[ °C]                temp. Topr.[ °C]
        VCC[V]                IOL[mA]
KOE-500xC        6                ±10                -25~+85                -25~+85
ELECTRO-OPTICAL CHARACTERISTICS(Ta=25 °C)
Type        Supply        Maximum        Output        Irradiance        Supply        Output
No.        voltage        Output        voltage        responsivity        current        pulse time
        Vo[V]        voltage        Typ[V]        mV/(mW/cm2)        Typ[mA]        [ms]
                Typ[V]                                tr        tf
KOE-5001C        2.7~5.5        4.9        2        250        1.1        20        13
                        (Ee=8mW/cm²)                (Ee=8mW/cm²)
KOE-5002C        2.7~5.5        4.9        2        62        1.1        9        9
                        (Ee=32mW/cm²)                (Ee=32mW/cm²)
KOE-5003C        2.7~5.5        4.9        2        15        1.1        4        4
                        (Ee=128mW/cm²)                (Ee=128mW/cm²)
三:Photodiode IC(PDIC)光电二极管芯片(PDIC公司
Model No.        Features        Wavelength        Supply voltage        Output off-set voltage        Current        Cut-off
                λ(nm)        Vcc(V)        Voff(mV)        Icc(mA)        frequency
                                                fc(MHz)
KOD-2410         CD Drives        780        6        -15 ~ +15        3        3
KOD-3005         CD Drives        780        12        -15 ~ +15        2.5        4
KOD-1017         CD Drives        780        2.5 ~ 5.5        -15 ~ +15        6        8
