查看: 1637|回复: 0
[供应] 供应Laser Diode Driver
发表于 2010-12-10 10:56:36 | 显示全部楼层 |阅读模式
Laser Diode Driver
The LDD100 employs a digitally programmable analogue end stage for flexible and accurate current control. Currents of up to 200A with pulse durations of 50ns to 3s are generated with rise and fall times of 25ns – essentially without overshoot. Due to the flexibility in setup and control, the LDD100 is practical for many laboratory applications. For automated measurements, the unit may be directly controlled via the USB interface. Alternatively, all parameters may be input via the graphical software or via the integrated keypad and LCD display.
LDD100.pdf (203.92 KB, 下载次数: 0)
