楼主: redflag
[分享]新版相对亮度曲线,修正了几个BUG,改进了图形显示
 楼主| 发表于 2003-11-1 03:19:00 | 显示全部楼层
从错误报告来看,你可能修改了此宏。
将此宏中的所有的内容另存为一个文件,如果是存在MACROS目录里面的话,用
IN CVMACRO:你取的宏的名字。
发表于 2003-11-3 19:52:00 | 显示全部楼层
同样的方法为什么不行,你的写的宏我是原封不动的拷贝的,能不能以文件的方式给我
发一个? zemax@sohu.com
谢谢!!!!!!!!!!!!!!!!1
 楼主| 发表于 2003-11-3 20:33:00 | 显示全部楼层
我已经发给你了.
发表于 2003-11-12 18:03:00 | 显示全部楼层
你的宏我是原封不动的拷贝的,不能用,你能把整个文件发给我吗?chenzhenyi714@sina.com,谢谢
发表于 2004-5-19 19:41:00 | 显示全部楼层
我看到的还是乱码呀,不好意思,又麻烦斑竹了
发表于 2004-5-22 03:21:00 | 显示全部楼层
乱码,麻烦斑竹了
发表于 2004-5-22 04:29:00 | 显示全部楼层
What I saw is also error code, please mail to me, thanks.
nytang1@yahoo.com.tw
 楼主| 发表于 2004-5-22 15:43:00 | 显示全部楼层
!***************************************************************************** ! Sequence: RELI.SEQ ! ! Purpose: Macro to plot Relative illumination vs. Fileds ! ! Syntax: in RELI ! ! ! Notes: This macro uses and overwrites buffer B0. ! ! Author: Doffey Date: 2003-07-15 ! ! History: 2003-07-15 ! !*****************************************************************************
lcl num ^numfld ^i ^j lcl num ^fld(25) ^reli(25) lcl str ^dim lcl num ^maxfld ver n
out n ^numfld == (num f)
^numfld == (num f) for ^i 1 ^numfld if (typ fld)="ANG" ^fld(^i) == (yan f^i) else if (typ fld)="OBJ" ^fld(^i) == (yob f^i) else if (typ fld)="IMG" ^fld(^i) == (yim f^i) else if (typ fld)="RIH" ^fld(^i) == (yri f^i) else ^fld(^i) == 0 end if end for out n BUF DEL B0 ! clear B0 buffer BUF YES ! turn on output buffer to collect output tra go BUF NO ! turn off output buffer
BUF FND "RELATIVE ILLUM:" ! find first occurrence
for ^i 1 ^numfld for ^j 1 (num w) buf mov ic jc+1 end for if not ((buf.typ ic jc+1) = "NUM") got ER end if ^reli(^i) == (buf.num ic jc+1)/100 ! ic updated by each BUF FND BUF FND ! find next occurrence end for out y wri "Calculating the Relative Illumniation..." wri wri " Field Relative Illumination" for ^i 1 ^numfld wri Q" 'dd.ddd' 'dd.ddd'" ^fld(^i) ^reli(^i) end for out n
! plot the MTF vs Field curves using UGR ugr
tit substr((tit),1,40) if (dim)="I" ^dim == " (inches)" else if (dim)="M" ^dim == " (mm)" else if (dim)="C" ^dim == " (cm)" else ^dim == "" end if if (typ fld)="ANG" xla "FIELD ANGLE" else if (typ fld)="OBJ" xla concat("OBJECT HEIGHT",^dim) else if (typ fld)="IMG" xla concat("IMAGE HEIGHT",^dim) else if (typ fld)="RIH" xla concat("REAL IMAGE HEIGHT",^dim) else end if yla "RELATIVE ILLUMINATION" xax 0 ! x and y cross at zero xde grd (^fld(^numfld))/10 yax 0 ymi 0 ! MTF range 0-1 by 0.1 yma 1.0 yde grd 0.1 yfo f 1 ! number formats for labels xfo f 2 ! create data point sets dpo 'Relative Illumination' spl 1 blu for ^i 1 ^numfld ^fld(^i) ^reli(^i) end for end go GOT END
wri lbl ER out y wri "ERROR: buffer error,Please check your lens!" out n lbl END !res ver y OUT YES
