查看: 13364|回复: 7
[供应] 1550 DFB -EA激光器 400RMB/PCS
 火.. [复制链接]
发表于 2011-4-4 11:36:39 | 显示全部楼层 |阅读模式
Fujitsu  10Gb/s 1550nm EA-Modulated Integrated DFB Laser
Modulator Integrated DFB Laser Diode Module
CW operation of DFB laser section
Modulation voltage applied only to modulator section
High speed butterfly package with GPO connection
Built-in optical isolator, monitor photodiode, thermistor, and thermo-electric cooler
APPLICATION
This MI laser is intended for intermediate reach applications (<=24km) at 10Gb/s.
DESCRIPTION
The Modulator Integrated DFB Laser (MI DFB Laser) has an electro-absorption modulator monolithically integrated with a conventional Distributed Feed-Back (DFB) laser. The modulation voltage is applied to the modulator section while the laser section operates CW allowing extremely low wavelength chirping. Extinction ratios of more than 8.2 dB can be achieved with 2.6 Vp-p modulation. The MI laser is installed in a butterfly type package. The module incorporates a highly stable optical coupling system. The module includes an optical isolator, monitor photodiode,thermistor and a thermoelectric cooler.
EMAIL:OECR_CWDM@hotmail.com
 楼主| 发表于 2011-4-4 11:37:09 | 显示全部楼层
自己顶一下
发表于 2011-4-4 15:50:09 | 显示全部楼层
有没有详细的spec或data sheet?
 楼主| 发表于 2011-4-4 22:14:02 | 显示全部楼层
回复 hope2008 的帖子
datasheet
datasheet.pdf
88.46 KB, 下载次数: 5, 下载积分: 光电贝 -1 元
datasheet
 楼主| 发表于 2011-4-4 22:31:37 | 显示全部楼层
回复 niwota0412 的帖子
datasheet2
datasheet(2).pdf
431.21 KB, 下载次数: 0, 下载积分: 光电贝 -1 元
 楼主| 发表于 2011-4-5 14:20:45 | 显示全部楼层
 楼主| 发表于 2011-4-6 20:07:52 | 显示全部楼层
 楼主| 发表于 2011-4-10 22:37:37 | 显示全部楼层
