查看: 4079|回复: 3
[求助] 求一个函数的翻译?
发表于 2011-4-29 22:20:12 | 显示全部楼层 |阅读模式
So far we see that the cavity can be characterized in three equivalent ways: by its decay time, its finesse, and its losses.
      the finesse of the cavity by inspection of Eq. (12). The finesse is defined as the ratio of the cavity free-spectralrange (FSR) to the intensity response function full width at half-maximum。
中的finesse怎么翻译啊~文章里好多这个词~还有F函数~不知道怎么翻译才对~麻烦各位大侠了。
发表于 2011-5-3 11:16:27 | 显示全部楼层
文献中这种函数不需要翻的吧,直接留英文名就可以,第一次出现时注明意义
 楼主| 发表于 2011-5-6 15:08:29 | 显示全部楼层
需要翻译啊,不过我找到了,谢谢你!
 楼主| 发表于 2011-5-6 17:11:36 | 显示全部楼层
finesse函数是谱线的精细度,定义为FSR/FW HM。FSR是自由光谱区,FW HM是峰值半宽度
