查看: 3599|回复: 6
有谁了解砷化镓(GaAS)的特性,要给它镀膜要注意些什么问题?
发表于 2003-7-26 00:38:00 | 显示全部楼层 |阅读模式
有谁了解砷化镓(GaAS)的特性,要给它镀高反膜要注意些什么问题?
发表于 2003-7-26 20:54:00 | 显示全部楼层
What do you want to know about it? I am also looking for the high reflection coating for GaAs or GaSb based laser diode. I know GaAs well, but little about the coating. The reflective index of GaAs is around 3.8. I think that’’s critical to the film design of coating.
发表于 2003-7-28 05:52:00 | 显示全部楼层
中心波长是多少?
 楼主| 发表于 2003-7-31 21:03:00 | 显示全部楼层
中心波长1550nm,要求R98%,我试镀过,用sio2和ta2o5,第一层为ta2o5,烘烤加热230℃,还有赫尔源辅助镀膜,但膜层不牢,脱膜!!
发表于 2004-4-1 04:04:00 | 显示全部楼层
as i know the index of GaAs is about 3.5
发表于 2004-4-1 16:40:00 | 显示全部楼层
Refractive index n versus photon energy for a high-purity GaAs.(no~5·1013 cm-3). Solid curve is deduced from two-beam reflectance measurements at 279 K. Dark circles are obtained from refraction measurements. Light circles are calculated from Kramers-Kronig analysis
[此贴子已经被作者于2004-4-2 9:22:37编辑过]
发表于 2004-4-5 16:57:00 | 显示全部楼层
对半导体激光器膜系计算,应该是从材料往空气入射吧,
即N0=3.5,Ns=1,对吗?
