查看: 94031|回复: 290
激光器拆卸图。
发表于 2003-6-13 22:56:00 | 显示全部楼层 |阅读模式
一个Nd:YAG 100 W CW 激光器。呵呵。
 楼主| 发表于 2003-6-13 23:00:00 | 显示全部楼层
激光器拆卸图。
Nd:YAG 100 W CW output laser with power supply, high voltage leads, and Wakefield Engineering heat exchanger. The laser cavity uses a single ARC lamp. All optics required to align and collimate the Nd:YAG beam and combine it with the beam of a pointing laser for delivery to an output fiber are included. The red HeNe pointing laser is a Melles Griot model 05-LHR-151. Its safety rating is 15 mW max and it is powered by a Melles Griot model 05-LPM-902-055 power supply. There are 3 beam blocking shutters, 1 solenoid used to insert 1 of 2 attenuators(?), 1 power sensor that reads directly from the cavity, and a second power sensor after the pair of solenoid positioned attenuators. There is also an interlock for the cover and there are two interlocks on the fiber collimator output connector. The 6 kW, Electronic Measurements, Inc. (now Lambda-EMI) model ESKI-150-40-2N-0704 arc lamp power supply requires single phase 208-220 VAC at 35 A for full output from the laser. The power supply has a DB-25 connector for remote programming. The Wakefield heat exchanger has a thermocouple, flow switch, and fan control module. Cooling water enters through the bottom of the laser and flows in series from the beam-dump to the cavity. There is a single thermocouple temperature sensor on the water line. The laser had 55 hours on the hours meter when disassembled. Weights: Laser - 35 pounds, Power Supply - 60 pounds, Cooler Assembly - 25 pounds, Pump - 50 pounds.
回复 支持 1 反对 0
 楼主| 发表于 2003-6-13 23:01:00 | 显示全部楼层
激光器拆卸图。
另外一个角度的图。
 楼主| 发表于 2003-6-13 23:02:00 | 显示全部楼层
激光器拆卸图。
另一角度的图。
 楼主| 发表于 2003-6-13 23:03:00 | 显示全部楼层
激光器拆卸图。
采用的水泵。
激光器拆卸图。
散热器
 楼主| 发表于 2003-6-13 23:04:00 | 显示全部楼层
激光器拆卸图。
电源接头。
发表于 2003-6-14 00:11:00 | 显示全部楼层
激光器拆卸图。
我是新人
请问YAG的激光头的价位一般是多少啊
发表于 2003-6-14 01:56:00 | 显示全部楼层
激光器拆卸图。
乏味的贴子果然有内涵,推
发表于 2003-6-14 06:44:00 | 显示全部楼层
激光器拆卸图。
牛。。。。。!
老外的东东果然精致。。。。。
不知道100w是不是基模?
具体尺寸是多少?
有没有相关技术文献啊。。。。。?
我想知道。。。。。。。
发表于 2003-6-15 23:59:00 | 显示全部楼层
激光器拆卸图。
我们有300W的TEM00模的光纤激光器,体重20KG。
发表于 2003-6-16 17:18:00 | 显示全部楼层
激光器拆卸图。
乏味兄果然厉害,原来激光器内部这么复杂啊!
