2003-7-1 17:13:00 | 显示全部楼层 | 阅读模式
[3]  Laser Amplifier Medium              Wavelength (nm)
  Fluorine (F2, Excimer-UV)                157
  Argon Fluoride (ArF, Excimer-UV)             193
  Krypton Chloride (KrCl, Excimer-UV)           222
  Krypton Fluoride (KrF, Excimer-UV)            248
  Frequency Quadrupled Nd:YAG (UV)             266
  Xenon Chloride (XeCl, Excimer-UV)            308
  Xenon Fluoride (XeF, Excimer-UV)             351
  Helium-Cadmium (HeCd, UV)                325
  Nitrogen (N2, UV)                    337
  Frequency Tripled Nd:YAG (NUV)              355
  Calcium Vapor Ion (NUV)                 374
  Gallium Nitride (GaN, violet/NUV)            400
  Strontium Vapor Ion (violet)               431
  Helium-Cadmium (HeCd, violet-blue)            442
  Frequency Doubled Nd:YVO4 (blue)             457
  Frequency Doubled Nd:YAG (blue)             473
  Krypton Ion (Kr+, blue)                 476
  Argon Ion (Ar+, green-blue)               488
  Xenon (Xe, green-blue)                  499
  Copper Vapor (Cu, green)                 510
  Argon Ion (Ar+, green)                  514
  Xenon (Xe, green)                    526
  Krypton Ion (Kr+, green)                 528
  Frequency Doubled Nd:YVO4 (green)            532
  Frequency Doubled Nd:YAG (green)             532
  Xenon (Xe, green)                    541
  Helium-Neon (HeNe, green)                543
  Helium-Mercury (HeHg, green)               567
  Krypton Ion (Kr+, yellow-green)             568
  Copper Vapor (Cu, yellow)                578
  Helium-Neon (HeNe, yellow)                594
  Helium-Neon (HeNe, orange)                612
  Helium-Mercury (HeHg, red-orange)            615
  Gold Vapor (Au, orange-red)               627
  Helium-Neon (HeNe, ornage-red)              633
  Krypton Ion (Kr+, red)                  647
  Alexandrite (red-NIR)                 655-815
  Gallium Aluminum Arsenide (GaAlAs, red-NIR)      670-830
  Chromium:Sapphire (Ruby, Cr:AlO3, red)          694
  CriSAF (CriSrAlF6, NIR)              780-920
  Gallium Arsenide (NIR)                  840
  Titanium:Sapphire (NIR)                840-1,100
  Neodymium:YVO4 (Nd:YV04, NIR)              914
  Neodymium:YAG (Nd:YAG, NIR)               946
  Ytterbium:KGW (Yb:KGW, NIR)             1,025-1,045
  Ytterbium:YAG (Yb:YAG, NIR)               1,031
  Neodymium:YLF (Nd:YLF, NIR)               1,053
  Chromium,Neodymium:GSGG (NIR)              1,061
  NeodymiumSB (NdSB, NIR)               1,062
  Neodymium,ChromiumSB (Nd,CrSB, NIR)         1,062
  Neodymium:YAG (Nd:YAG, NIR)               1,064
  Neodymium:YVO4 (Nd:YV04, NIR)              1,064
  Neodymium:KGW (Nd:KGW, NIR)               1,067
  Helium-Neon (HeNe, NIR)                 1,152
  Neodymium:YAG (Nd:YAG, NIR)               1,330
  Erbium:Glass (NIR)                   1,540
  Thulium:YAG (Tm:YAG, MIR)              2,008-2,018
  Chromium,Thulium:YAG (Cr,Tm:YAG, MIR)          2,010
  ThuliumuAG (TmuAG, MIR)             2,020-2,030
  Thulium,Holmium:YLF (Tm,Ho:YLF, MIR)         2,047-2,059
  Holmium:YLF (Ho:YLF, MIR)                2,060
  Chromium,Thulium,Holmium:YAG (Cr,Tm,Ho:YAG, MIR)    2,090
  Holmium:YAG (Ho:YAG, MIR)                2,100
  Hydrogen Fluoride (HF, MIR)               2,700
  Erbium:YAG (Er:YAG, MIR)                2,940
  Helium-Neon (HeNe, MIR)                 3,391
  Deuterium Fluoride (DF, MIR)             3,600-4,200
  Carbon Dioxide (CO2, FIR)                9,600
  Carbon Dioxide (CO2, FIR)               10,600
Notes:
1.NUV = Near-UV, NIR = Near-IR, MIR = Mid-IR, FIR = Far-IR.
2.Wavelengths have been rounded to the nearest nm.
3.Where a laser may operate at multiple discrete wavelengths, only the strongest ones may be listed.
4.KGW = Potassium Gandolinium Tungstate, KGd(WO4)2.
5.YAG = Yttrium Aluminum Garnet.
6.YLF = Yttrium Lithium Fluoride.
Dye Laser Dyes and Peak Emission Wavelengths
Dye lasers can operate at a wide range of wavelengths spanning the visible spectrum and well into the IR to UV
depending on the particular dye used as the lasing medium. This is a list of some commercially available laser dyes
along with their Peak Emission Wavelength (PEW). Source: LambdaPhysik.
  PEW-nm Dye Name
    330  BM-Terphenyl     491  Coumarin 6H     775  NCI
  340  PTP         500  Coumarin 307     780  Methyl-DOTCI
  350  TMQ         501  Coumarin 50     795  Styryl 11
  357  BMQ         504  Coumarin 314     800  Rhodamine 800
  359  DMQ         510  Coumarin 51     840  Styryl 9
  360  Butyl-PBD      515  Coumarin 3      841  Styryl 9 (M)
  364  PBD         521  Coumarin 334     863  IR 125
  365  TMI         522  Coumarin 522     876  DTTCI
  369  QUI         535  Coumarin 7      880  IR 144
  370  PPO         536  Bril. Sulfaflavine  881  Styryl 15
  372  PPF         537  Coumarin 6      885  DNTTCI
  374  PQP         540  Coumarin 153     930  DDCI-4
  378  BBD         552  Uranin        945  Styryl 14
  380  Polyphenyl 1     553  Fluorescein 27    950  IR 132
  381  Polyphenyl 2     555  Fluorol 7GA     994  Styryl 2D
  386  BiBuQ        570  Rhodamine 110    1060  IR 25
  390  Quinolon 390     575  Rhodamine 19
  393  TBS         590  Rhodamine 6G
  395  alpha-NPO      590.1 Rhodamine 6G (Perchlorate)
  399  Furan 2       610  Rhodamine B
  400  PBBO         610.1 Rhodamine B (Perchlorate)
  409  DPS         620  Sulforhodamine B
  410  Stilbene 1      640  Rhodamine 101
  415  BBO         650  DCM
  420  Stilbene 3      650.1 DCM-special
  422  Carbostyryl 7    660  Sulforhodamine 101
  423  POPOP        670  Cresyl Violet
  424  Coumarin 4      675  Phenoxazone 9
  425  Bis-MSB       690  Nile Blue
  430  BBOT         695  Oxazine 4
  435  Carbostyryl 3    700  Rhodamine 700
  440  Coumarin 120     710  Pyridine 1
  450  Coumarin 2      721  Oxazine 170
  466  Coumarin 466     725  Oxazine 1
  470  Coumarin 47     727  Oxazine 750
  480  Coumarin 102     730  Pyridine 2
  481  Coumarin 152A    750  Styryl 6
  485  Coumarin 152     755  Styryl 8
  490  Coumarin 151     771  Pyridine 4
4586查看13回复
2003-7-3 01:29:00
wavelength and laser
为什么没人给我留帖子?
资料没有用?还是卖的贵???
555555555
2003-7-3 01:47:00
OK BUY IT
2003-7-3 05:09:00
是你卖的太便宜了吧
2003-7-3 09:31:00
hehe, 不错啊
2003-7-3 16:23:00
呵呵,谢谢大家支持,
好的资料大家共享吗!
我要钱也没有用的!
有了好的资料,我再发帖
2003-7-6 00:09:00
能够翻译一下吗?
2003-7-8 16:41:00
不是吧,很有难度啊!:(
2003-7-8 21:17:00
very good
2003-7-8 22:14:00
问个问题:波长在222nm处的Krypton Chloride (KrCl, Excimer-UV)激光器国内市场上有吗?
2003-7-9 16:48:00
没有作过这方面的调查,不过听说紫外激光技术还不是很完善,所以,市场上即使有也很少!
2003-7-9 17:05:00
谢谢solojackie兄,我调查到了市场上有的紫外激光器,不仅价格很贵并且性能很不稳定,实用价值不高
12下一页
