2003-7-11 19:13:00 | 显示全部楼层 | 阅读模式
激光焊接专用气动喷嘴的研究
唐霞辉 朱海红 朱国富 李适民 李再光
摘要:针对高功率CO2激光焊接,作者试验研究出一种气动喷嘴,用以保护导光聚焦系统,防止焊接过程中金属飞溅造成的镜片污染,通过对飞溅粒子运动轨迹的理论分析,设计出合理的喷嘴结构。采用气动喷嘴和普通同轴喷嘴,比较试验出高功率激光焊接过程中导光系统污染对激光功率的衰减、焊缝气孔率及有效熔深等的影响以及聚焦镜片上飞溅粒子的分布。结果表明:气动喷嘴从本质上减少了聚焦镜上飞溅粒子的数量,使激光功率损失减少,有效焊接长度增加,并且横向气流没有对焊缝造成任何不利影响。
关键词:激光焊接 飞溅污染 气动喷嘴 镜片保护
Study on aerodynamic nozzle specialized for laser welding
Tang Xiahui, Zhu Haihong, Zhu Guofu, Li Shiming, Li Zaiguang
(National Engineering Research Center for Laser Processing,HUST,Wuhan,430074)
Abstract:In this paper, an aerodynamic nozzle was investigated for protecting the beam deliveray system and preventing optics pollution from ejected particle vaporized on metallic surface during high power CO2 laser welding. The suitable nozzle structure was designed on the basis of theoeretical analysis on moving trajectory of the ejected particle. The comparing experiments between aerodynamic nozzle and ordinary nozzle were performed to examine the influence of optics pollution on loss of laser power, porosity percentage of weld-section&#59; and efficient penetration depth, and also to inspect the distrubution of ejected particle on optics during laser welding. The studied results show that the aerodynamic nazzle substantially reduced the particle amount on the optics, so the loss of the laser power delivered to the workpiece was reduced, the effective weld lentgh was increased.The examination of the weld structure ensured that there was no interference with the quality of the weld due to the cross-flow.
  Key words:laser welding ejecta pollution aerodynamic nozzle optics protection
引言
  就几类典型的激光加工而言,激光熔覆和热处理焦距长、飞溅小、镜片污染少;激光切割喷嘴出气口小,气压大,能有效防止飞溅;而激光焊接焦距较短,熔池反应剧烈,飞溅大,但保护气流量有限,故极易造成镜片污染,成为激光焊接产业化中一个非常棘手的问题。镜片污染导致激光束产生散射,聚焦不良,长时间工作会出现焦点漂移,传输到工件的激光功率受到损失,使激光焊接性能变差。镜片的频繁清洗和更换严重影响工作效率,大量的飞溅使晶体镜片因热畸变而破裂。有色金属(如Al,Cu)以及粉末冶金材料(如金刚石锯片)等的激光焊接,飞溅尤其严重,极易导致镜片毁坏。
  传统的激光焊接喷嘴为圆锥状,分两路气体:一路同轴气体用于保护焊缝,一般采用惰性气体Ar气、He气;另一路为侧吹辅助气体,用于控制等离子体,减少等离子体激光的屏蔽,增加熔深[1]。传统喷嘴同轴保护气体流量有严格限制,喷嘴内径为2.5mm时,气流量为7~9L/min,气流量太大,熔池翻动厉害,焊缝凹凸不平,出现孔洞。
  气动窗口已在本单位的10kW CO2激光器上得到应用,其目的是使激光谐振腔内工作气体与外界空气隔离。我们研究的气动喷嘴是在激光束垂直方向通以高速气流,在光学元件的下方形成气体隔离层,阻挡金属飞溅物的上冲。这种喷嘴的研制成功及推广应用,对于解决易飞溅金属(如粉末冶金材料)的高功率激光焊接,具有重要的理论意义和实用价值。
1 理论分析与结构设计
1.1 气体动力学分析
  求解气动喷嘴内横向气动窗口的尺寸及所需的气体流量[2]的运动方程为:
F=ρv2CdA/2       (1)
F=m(-a)      (2)
式中,F为气体作用于飞溅粒子上的阻力,Cd为阻力系数,A为粒子在运动方向的正面面积,ρ为气流中空气密度,v为粒子相对气流的运动速度,m为飞溅粒子质量,a为粒子因阻力产生的加速度(负加速度)。
  根据有关文献及相关假设来估算飞溅粒子进入气流层后的运动轨迹[3],飞溅粒子近似为球形,直径Φ为0.1mm,起始运动速度为8m/s,阻力系数Cd近似为无压缩、无粘性的流体中的阻力系数,根据文献[4]可以对粒子尺寸和初始运动速度在一定范围内进行理想分类,并在不同气体流速下解方程。图1为不同气流速度、粒子速度、粒子质量下求解的运动轨迹。根据现有的焦距f=100mm的圆锥喷嘴,一个粒子垂直向上运动30mm,必须水平运动20mm才不至于落到聚焦镜片上[4],按此推算,图1中当横向气体流速为15~20m/s正好合适。
Fig.1 Curves of ejected-particle trajectory in cross-flow
a—vp =7m/s&#59;va=vary&#59;Φ=0.1mm b—vp=vary&#59;va=15m/s&#59;Φ=0.1mm
 c—vp=7m/s&#59;va=15m/s&#59;Φ=vary
vp—initial particle velocity in y-direction&#59;va—aerodynamic
cross-flow velocity in x-direction&#59; Φ—particle diameter
1.2 气动喷嘴的结构设计
  喷嘴结构基于聚焦镜片焦距和空间条件限制,整体分成可拆卸的4个部分,以便安装及机械加工,局部损坏后可进行更换。如图2所示,4个部分分别为横流进气通道、横流出气通道、圆柱基体、圆锥尖端。进气通道设有一块方形金属丝网,以利气体均匀挺直、减少死点,通过调整不同的丝网来确定最佳气流面积及流速。
Fig.2 Aerodynamic nozzle structure
2 试验条件及方法
  采用美国Coherent公司1. 25kW轴流CO2激光器,准基模输出。分别用ZnSe透射式聚焦镜和金属反射式聚焦镜,其45°反射镜为Cu镜镀Mo;反射式抛物聚焦镜为Mo,镜片便于擦洗。焊接试验材料为45#钢,表面抛光后,用等离子体热喷涂一层0.2mm的-200目Fe粉,200mm×200mm×4mm尺寸的方形试样位于数控工作台上,焊后沿焊缝横截面剖开,用美国M400-H1金相显微镜观察并测量焊缝形貌。主要焊接工艺参数为:激光功率P=1.2kW,焊速v=20mm/s,焦距f=100mm,离焦量f=-1.5mm,焊缝保护气体流量7L/min,Ar气保护。
  用手持式热量功率计测量激光经聚焦镜后照射到工件上的激光功率,以考察不同喷嘴保护时,聚焦系统对激光功率的损耗。对于不同的镜片保护试验,焊接完成后,将镜片取下,用干净胶带将镜片上沉积的飞溅粒子粘取下来,在低倍放大镜下观察并测量其尺寸,记录下特定区域内的粒子数分布。
3 试验结果及其分析
3.1 镜片破坏性试验
  首先采用ZnSe透镜聚焦,普通喷嘴同轴保护,焊接2800mm后,镜片破裂,据观察,破裂镜片表面粘有一层细颗粒飞溅物,覆盖层阻挡激光束的传输,经激光功率测量,由飞溅污染而引起的透射激光能量损失高达25%,过高的热量使镜片热畸变而损坏;另一片ZnSe镜片采用气动喷嘴保护,横向气流量200L/min,焊接7000mm后,镜片完好无损。同时研究了横向气流对喷嘴尖端同轴气流关系,结果也表明,在横向气流关、开瞬间及正常工作时,同轴喷嘴尖端几乎测不出横向气流附加的影响,即对焊缝的保护效果无任何不利影响。
3.2 激光传输效率比较
  通过聚焦系统后的被测激光功率与之前激光功率之比为传输效率,其比值随焊接长度增加而下降,如图3所示,在焊接相等长度2800mm后,普通喷嘴传输效率只有71%,而气动喷嘴为96%,提高了25%。据此推测,当传输效率降至71%时,气动喷嘴可以焊接18000mm,是普通喷嘴的6倍多。
Fig.3 Efficiency of laser power delivered to
workpiece as a function of weld length
3.3 飞溅粒子分布
  粒子分布如图4所示,与普通喷嘴相比,气动喷嘴几乎可去除80%的较小粒子(小于0.2mm2)和所有大于0.2mm2的粒子。
Fig.4 Distrubution of particles deposited on focus optics
3.4 焊缝质量分析
  焊接特征比较分析同样说明两种喷嘴之间的区别,普通喷嘴开始出现深熔焊,一定长度后变成有限深度的传热焊,镜片破裂时,深熔焊缝与传热焊缝的长度之比约为1。据试验现象可看到,焊缝的变化是由于镜片污染使光束不稳定,激光功率下降。气动喷嘴焊缝检验结果表明,95%总长度的焊缝为深熔焊。
  焊缝横截面的气孔分布面积如图5所示,据观察,气动喷嘴焊缝横截面有几个小气孔(4×103~6×103μm2数量级),焊缝平均气孔率约为2%,普通喷嘴出现单一大气孔(105μm2数量级),平均气孔率高达17%,据分析,气孔率不同的原因是由于采用气动喷嘴保护镜片,焊缝保护气体流量可以降低,从而减少了对熔池的扰动,故气孔率低,而普通喷嘴为保护镜片,必须采用较大气流量,使焊缝气孔率增加[6]。
Fig.5 Porosity of weld cross-section
4 结论
  在焊接喷嘴结构中,横向气动喷嘴在保护反射式和透射式光学元件方面非常有效,ZnSe镜片在横向气流保护下,焊接7000mm后仍完好无损,而普通喷嘴焊接2800mm后即损坏,同样焊接长度,与普通喷嘴相比,气动喷嘴几乎能去除80%的飞溅粒子。研究结果表明,气动喷嘴的优势为:(1)激光束通过带气动保护的聚焦镜传到工件上的功率损耗可减少25%;(2)稳定深熔焊缝可达总焊接长度的90%以上;(3)聚焦镜两次清洗之间的焊接长度为普通喷嘴的6倍;(4)焊缝气孔率低于2%。(5)喷嘴尖端无横向气流的影响。
2448查看1回复
2003-7-11 23:01:00
[转帖]激光焊接专用气动喷嘴的研究
看不到图,能不能发一份到我的邮箱?
zengshenbo@163.com
先谢谢了!!
