查看: 19803|回复: 65
[其它] Material: Nd:YAG/Cr:YAG Monolithic Liquid Epitaxy Grown and Co-doped Cz Tech
发表于 2011-5-19 13:43:59 | 显示全部楼层 |阅读模式
Material: Nd:YAG/Cr:YAG Monolithic Liquid Epitaxy Grown and Co-doped Czochralski Technique
Nd Dopant: 1% to 3.5% Nd
Cr Alpha: 0.5 cm-1 to 7 cm-1
Cross Section Dimensions: 1.3 mm +/- 0.1 mm
Length Dimensions: 0.5 mm to 3.5 mm including Cr layer
Flat-Flat Cavities
Coated with HR and PR dielectric IBS films for both 946 nm and 1064 nm output
Pulse widths: 0.4 ns to 3 ns
Pulse Energies: 1 microjoule to 20 microjoules
Pulse Rep Rates: 1 to 100 kHz
Ready for mounting and operation
 楼主| 发表于 2011-5-19 16:22:13 | 显示全部楼层
 楼主| 发表于 2011-5-19 16:23:29 | 显示全部楼层
 楼主| 发表于 2011-5-20 08:23:43 | 显示全部楼层
 楼主| 发表于 2011-5-20 08:44:42 | 显示全部楼层
300ps to 3 ns
1 uj to 20 uj
1 to 100 kHz
1064 nm
946 nm
532 nm
473 nm
266 nm
 楼主| 发表于 2011-5-20 10:06:06 | 显示全部楼层
 楼主| 发表于 2011-5-20 10:29:39 | 显示全部楼层
 楼主| 发表于 2011-5-20 10:34:58 | 显示全部楼层
 楼主| 发表于 2011-5-20 10:39:52 | 显示全部楼层
 楼主| 发表于 2011-5-20 11:21:56 | 显示全部楼层
 楼主| 发表于 2011-5-20 11:23:12 | 显示全部楼层
头像被屏蔽
发表于 2011-5-20 13:12:53 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
