查看: 1960|回复: 1
How to calculate lens cut off frequency
发表于 2004-1-9 10:21:00 | 显示全部楼层 |阅读模式
is lens cut off frequency the same as MTF?
Say I have a periodic bar pattern as input, distance 3f/2 away there is F/4 lens, and after distance 3f I should have the image.
my solution is: diffraction limit is 1.22*wavelength*3f/D=14.64wavlength, then on the image plane, I assume the image of two bars is 14.64*wavelength, then at object plane, the cloest distance is 7.32*wavelegnth.
This number is very high, assume wavelength is 0.5um, it is 300+ cycles/mm. but normal lens MTF is less than 100. Where did I do wrong?
Thanks
 楼主| 发表于 2004-1-11 06:42:00 | 显示全部楼层
nobody help me on this? this is a question on our PhD qualify exam a couple years ago.
