2004-4-1 19:45:00 | 显示全部楼层 | 阅读模式
愚人节的起源
Unlike most of the other nonfoolish holidays, the history of April Fool's Day, sometimes called All Fool's Day, is not totally clear. There really wasn't a "first April Fool's Day" that can be pinpointed on the calendar. Some believe it sort of evolved simultaneously in several cultures at the same time, from celebrations involving the first day of spring.
The closest point in time that can be identified as the beginning of this tradition was in 1582, in France. Prior to that year, the new year was celebrated for eight days, beginning on March 25. The celebration culminated on April 1. With the reform of the calendar under Charles IX, the Gregorian Calendar was introduced, and New Year's Day was moved to January 1.
However, communications being what they were in the days when news traveled by foot, many people did not receive the news for several years. Others, the more obstinate crowd, refused to accept the new calendar and continued to celebrate the new year on April 1. These backward folk were labeled as "fools" by the general populace. They were subject to some ridicule, and were often sent on "fools errands" or were made the butt of other practical jokes.
This harassment evolved, over time, into a tradition of prank-playing on the first day of April. The tradition eventually spread to England and Scotland in the eighteenth century. It was later introduced to the American colonies of both the English and French. April Fool's Day thus developed into an international fun fest, so to speak, with different nationalities specializing in their own brand of humor at the expense of their friends and families.
In Scotland, for example, April Fool's Day is actually celebrated for two days. The second day is devoted to pranks involving the posterior region of the body. It is called Taily Day. The origin of the "kick me" sign can be traced to this observance.
Mexico's counterpart of April Fool's Day is actually observed on December 28. Originally, the day was a sad remembrance of the slaughter of the innocent children by King Herod. It eventually evolved into a lighter commemoration involving pranks and trickery.
Pranks performed on April Fool's Day range from the simple, (such as saying, "Your shoe's untied!), to the elaborate. Setting a roommate's alarm clock back an hour is a common gag. Whatever the prank, the trickster usually ends it by yelling to his victim, "April Fool!"
Practical jokes are a common practice on April Fool's Day. Sometimes, elaborate practical jokes are played on friends or relatives that last the entire day. The news media even gets involved. For instance, a British short film once shown on April Fool's Day was a fairly detailed documentary about "spaghetti farmers" and how they harvest their crop from the spaghetti trees.
April Fool's Day is a "for-fun-only" observance. Nobody is expected to buy gifts or to take their "significant other" out to eat in a fancy restaurant. Nobody gets off work or school. It's simply a fun little holiday, but a holiday on which one must remain forever vigilant, for he may be the next April Fool!
[转帖]关于愚人节!
[转帖]关于愚人节!
3662查看16回复
2004-4-1 19:48:00
每年4月1日,是西方也是美国的民间传统节日——愚人节。 愚人节起源于法国。 1564年,法国首先采用新改革的纪年法——格里历(即目前通用的阳历),以1月1日为一年之始。但一些因循守旧的人反对这种改革,依然按照旧历固执地在4月1日这一天送礼品,庆祝新年。主张改革的人对这些守旧者的做法大加嘲弄。聪明滑稽的人在4月1日就给他们送假礼品,邀请他们参加假招待会,并把上当受骗的保守分子称为“四月傻瓜”或“上钩的鱼”。 从此人们在4月1日便互相愚弄,成为法国流行的风俗。18世纪初,与人接习俗传导英国,接着又被英国的早期移民带到了美国。
  愚人节时,人们常常组织家庭聚会,用水鲜花和雏菊把房间装饰一新。典型的传统做法是布置假环境,可以把房间布置得像过圣诞节一样,也可以布置得像过新年一样,待客人来时,则祝贺他们“圣诞快乐”或“新年快乐”,令人感到别致有趣。4月1日的鱼宴,也是别开生面的。参加鱼宴的请帖,通常是用纸板做成的彩色小鱼。餐桌用绿、白两色装饰起来,中间放上渔港和小巧玲珑的钓鱼竿,每个钓竿上级一条绿色飘带,拴着送给客人的礼物——或是一个精巧的塞璐路鱼,或是一个装满糖果的鱼篮子。不言而喻,鱼宴上所有的菜都是用鱼做成的。
  在愚人节的聚会上,还有一种做假菜的风俗。有人曾经描述过一个典型的愚人节菜谱:先是一道“色拉”,莴苣叶上撒满了绿胡椒,但是把叶子揭开后,才发现下面原来是牡蛎鸡尾酒;第二道才是“烤土豆”,其实下面是面包屑和鲜蘑;此后上的菜还有用蟹肉作伪装的烧鸡和埋藏在西红柿色拉下面的覆盆子冰淇淋。饭后,客人还可以从丸药盒里取食糖果。
  不过愚人节最典型的活动还是大家互相开玩笑,用假话捉弄对方。有的人把细线拴着的钱包丢在大街上,自己在暗处拉着线的另一端。一旦有人捡起钱包,他们就出其不意地猛然把钱包拽走。还有人把砖头放在破帽子下面搁在马路当中,然后等着看谁来了会踢它。小孩们会告诉父母说自己的书包破了个洞,或者脸上有个黑点,等大人俯身来看时,他们就一边喊着“四月傻瓜”,一边笑着跑开去。总之,每逢愚人节这一天,动物园和水族馆还会接道不少打给菲什(鱼)线生或莱昂(狮子)先生的电话,常常惹得工作人员掐断电话线,以便减少麻烦。
2004-4-1 19:58:00
易容术2:
    设法取得被愚者的即时通讯软件的联系号码,如Oicq号码。
    自己重新申请一个Oicq号码,按照被愚者的详细情况,投其所好填写个人资料。
    将被愚者加入到你所申请的新号码的联络清单中,然后抓住对方弱点(不要告诉我你不知道朋友的一些小弱点哦)开始对其进行“大型轰炸”,直至暴露。
    和不让被愚者知道自己是谁的易容术1不同的是,本术主要是不让对方知道你是谁。因此,在使用中一定要注意隐藏,尽量不要让对方对你有疑心。
    破解妙方:
    无论何时何地都千万要记住再离开自己的电脑前,将系统锁定。一旦怀疑中招,那么自己只能小心、细心的去观察破解了。
    神功2、乾坤大挪移
    顾名思义,“乾坤大挪移”就是将被愚者电脑中的一些设置偷梁换柱,主要方法有以下几种:
    利用麦克风和Windows自带的“录音机”程序录下一些恐怖或者离奇的声音,然后将其设置为Windows开机声音(关机声音)。这样当被愚者开(关)机的时候,冷不丁的必被吓一跳。
    将被愚者常用的一些应用程序的快捷方式目标改变(最好是换成一些好玩的整蛊软件),让其点击快捷方式开启程序后,却发现启动的不是和快捷方式相对应的程序。注意:一定要将快捷方式的图标保持和原来的程序一致。
    将被愚者电脑中的“我的文档”所对应的目标文件夹改变,让被愚者误以为辛辛苦苦撰写的文档全部消失。
    打开被愚者的Foxmail并任意新建一个帐户,然后打开存贮邮件的文件夹,将其常用的帐户下的收件箱文件(in.box)剪切备份至安全地带(不易被发现也不易被误删除),再将刚才新建帐打开户下的收件箱文件复制到被愚者常用帐户下,最后回到Foxmail,将你刚才新建的帐户删除。
    打开【控制面板】-【鼠标】,将【鼠标键配置】中的使用习惯改成相反的设置。
    使用乾坤大挪移的时候一定要小心谨慎,因为一不小心就会走火入魔、铸成大错。虽然此法较为危险,但是其整蛊效果却绝对一流,足以让被愚者心跳加快,血压升高,浑身冒冷汗。
    破解绝招:要破解该法相当简单,即不给任何人可以接近你电脑的机会。
2004-4-1 19:59:00
神功3、移形换影法
    修炼方法:
    抓住被愚对象不在电脑旁边的几分钟或者故意将其支开(不会不知道怎么做吧?)。
    施展“凌波微步”快速接近被愚对象的电脑。
    在Win98/2000下将其所有打开的窗口最小化,然后使用Print Screen键捕捉其桌面。
    打开“画图”程序,按下Ctrl+v粘贴刚才所抓图片,并将其保存为*.bmp格式。
    回到桌面,将刚才所保存的图片设置为桌面,视对方具体操作系统不同方法也不同,具体如下:
    Win98:在桌面点击鼠标右键,选择【属性】-【Web】,将【按Web页方式查看活动桌面】选项选中,然后点击【效果】,选中【按WEB页查看活动桌面时隐藏桌面图标】,最后点击【背景】将刚才所保存的图片设置为桌面,点击【确定】完成设置。
    Win2000:在桌面点击鼠标右键,选择【活动桌面】,然后在【显示WEB内容】前打上对勾,接下来再次在桌面点击鼠标右键并选择【活动桌面】,将除【显示WEB内容】外的所有选项前的对勾全部去掉,最后在桌面点击鼠标右键选择【属性】-【背景】,将刚才所保存的图片设置为桌面,点击【确定】完成设置。
    在任务栏点击鼠标右键选择【属性】,在【自动隐藏】选项前打上对勾,点击【确定】将任务栏隐藏。如果你觉得这样隐藏仍不够保险的话,那么就使用“拖动神功”将任务栏托至屏幕最下方。OK!大功告成,快回到你的座位前,准备偷偷的笑吧。
    施法效果:
    当被愚对象按下桌面以及任务栏上任何图标的时候,却任何反应也不会有,就算误以为是系统死机而重新启动电脑也无济于事。
    破解妙方:
    你可以将鼠标移至任务栏的时间处,如果不是正常桌面的话,那么将不会显示出当前的年月日,这样你就会很轻松的识别出对手的小把戏。而最彻底的破解防范办法莫过于离开自己的电脑前记得将系统锁定,如此一来谁也不要想再你离开的时候做手脚了。
2004-4-1 20:01:00
长知识了!
2004-4-1 20:01:00
神功4、硬件大法 如果被愚者对于硬件一无所知的话,那么本招是对付他们最好的办法。你可以在他们还没有上班前,将其显示器的电源插头或者鼠标的插头搞松,这样当被愚者上班打开自己的电脑的时候就会发现显示器黑屏或者提示鼠标找不到,到时候你再神勇现身,轻松将其问题搞定,那么对方非但不会想到被你整蛊,而且还会大力感激于你!对于MM而言,此招更为有效,是整蛊还是英雄救美,到时候可就看你的表现了^_^。 接下来再为大家介绍更为“歹毒”的一招,那就是将被愚者显示器的对比度调整至最低(以屏幕漆黑为原则),如此一来,除非对方心细如发,否则极难发现真正的原因。如果被愚者稍懂硬件知识且又胆大妄为的话,呵呵,那么你就可以有很大的机会看着其将自己的电脑“大卸八块”的精彩场景! 专业破解:细心观察显示器的电源指示灯,至于能不能发现问题所在,就看你的修行深不深了。
神功5、高科技秘密武器 如果你觉得以上那些方法实在是太累或者不易实现的话,那么你可以试试我们整蛊者的高科技秘密武器――整蛊软件(详见)。只要你将这些以假乱真的格式化硬盘、删除文件类软件发送给被愚者,用你的“甜言蜜语”让其忍不住的去执行,那么你就可以看到对方目瞪口呆的表情了!嘿嘿! 防御措施:“宁可错杀一千,也不可放过一个”愚人节那天无论如何也不要执行那些朋友发送过来的各种软件。 神功6、连环整蛊 整蛊秘计中最难修炼,境界最高的就是――连环整蛊。只要你的头脑够聪明,够灵活,那么你完全可以将所有的整蛊方法串连起来,一环扣一环,设下天罗地网,让被愚者无处可逃、哭笑不得。此法精义只可意会,不可言传,其中奥妙,整蛊者只能慢慢去领悟了。 防范法则:小心,小心,再小心;细心,细心,再细心。
2004-4-1 21:07:00
非常好,可惜没机会实施
2004-4-2 12:11:00
fffffffff
2004-4-2 12:12:00
2004-4-2 12:13:00
2004-4-2 12:13:00
2004-4-2 12:13:00
12下一页
