查看: 15064|回复: 45
Materials Guide - Melting Points, Bulk Densities and Z-Ratios
发表于 2004-4-2 16:52:00 | 显示全部楼层 |阅读模式
MATERIAL SYMBOL
MELTING TEMPERATURE (degree C)
BULK DENSITY (g/cm3)
Z-RATIO
Aluminum Al
660
2.70
1.08
Antimony Sb
631
6.62
0.768
Arsenic As
612
5.73
0.966
Barium Ba
729
3.5
2.1
Beryllium Be
1287
1.85
0.543
Bismuth Bi
271
9.78
0.79
Boron B
2067
2.535
0.389
Cadmium Cd
321
8.65
0.682
Cadmium sulfide CdS
1750
4.83
1.02
Cadmium telluride CdTe
1041
6.20
0.980
Calcium Ca
839
1.55
2.62
Calcium fluoride CaF2
1360
3.18
0.775
Carbon (diamond) C
3550
3.52
0.22
Carbon (graphite) C
3652
2.25
3.26
Chromium Cr
1857
7.20
0.305
Cobalt Co
1495
8.71
0.343
Copper Cu
1083
8.93
0.437
Copper(I) Sulfide (Alpha) Cu2S
1100
5.6
0.69
Copper(I) Sulfide (Beta) Cu2S
1100
5.8
0.67
Copper(II) Sulfide CuS
1100
4.6
0.82
Gallium Ga
30
5.93
0.593
Gallium arsenide GaAs
1238
5.31
1.59
Germanium Ge
937
5.4
0.516
Gold Au
1063
19.3
0.381
Gold Germanide AuGe(12%)
17.63
0.3972
Indium In
157
7.24
0.841
Indium antimonide InSb
535
5.76
0.769
Indium tinide InSn(80-20wt%)
7.25
0.8176
Iridium Ir
2434
22.4
0.129
Iron Fe
1536
7.86
0.349
Lead Pb
327
11.342
1.13
Lead sulfide PbS
1114
7.50
0.566
Lithium Li
181
0.534
5.9
Lithium fluoride LiF
896
2.64
0.774
Magnesium Mg
649
1.74
1.61
Magnesium oxide MgO
2642
3.58
0.411
Manganese Mn
1244
7.44
0.377
Manganese Sulfide MnS
3.99
0.94
MATERIAL SYMBOL
Z-RATIO
Mercury Hg
-39
13.6
0.74
Molybdenum Mo
2617
10.2
0.257
Nickel Ni
1453
8.85
0.331
Nickel chromide NiCr(80-20wt%)
8.52
0.3258
Niobium Nb
2467
8.57
0.493
Palladium Pd
1552
12.16
0.357
Platinum Pt
1770
21.37
0.245
Potassium chloride KCl
770
1.98
2.05
Selenium Se
221
4.82
0.864
Silicon Si
1412
2.34
0.712
Silicon dioxide (fused quartz) SiO2
1610
2.20
1.07
Silicon monoxide SiO
1702
2.13
0.87
Silver Ag
961
10.492
0.529
Silver bromide AgBr
432
6.47
1.18
Silver chloride AgCl
455
5.56
1.32
Sodium Na
98
0.971
4.8
Sodium chloride NaCl
800
2.17
1.57
Sulfur S8
115
2.07
2.29
Tantalum Ta
2977
16.6
0.262
Tellurium Te
450
6.25
0.900
Tin Sn
232
7.30
0.724
Titanium Ti
1670
4.50
0.628
Titanium oxide TiO
4.9
not available
Titanium dioxide TiO2
1825
4.26
0.40
Tungsten W
3380
19.3
0.163
Tungsten carbide W2C
2860
15.6
0.151
Uranium U
1132
18.7
0.238
Vanadium V
1902
5.87
0.530
Ytterbium Yb
824
6.96
1.13
Yttrium Y
1526
4.48
0.835
Zinc Zn
420
7.14
0.514
Zinc oxide ZnO
1975
5.61
0.556
Zinc selenide ZnSe
1100
5.42
0.722
Zinc sulfide ZnS
1700
4.10
0.775
Zirconium Zr
1852
6.53
0.60
发表于 2004-4-2 17:04:00 | 显示全部楼层
好冬冬
多谢楼主了
不过怎么没有Al2O3呀?
哪位能补上?
发表于 2004-4-3 00:27:00 | 显示全部楼层
MATERIAL SYMBOL
Z-RATIO
Aluminum OxideAl2O3
na
3.97
0.336
发表于 2004-4-3 20:50:00 | 显示全部楼层
coatingli的东西好像很多哇
发表于 2004-4-3 23:26:00 | 显示全部楼层
象这样的参数,如果折射率改变的话,会不会也有变化呢?
发表于 2004-4-4 21:21:00 | 显示全部楼层
Thanks
发表于 2004-4-8 18:37:00 | 显示全部楼层
how about ZrO2, Hf, HfO2?
头像被屏蔽
发表于 2004-4-17 19:40:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2004-4-21 03:07:00 | 显示全部楼层
3Q very much
发表于 2004-5-1 04:01:00 | 显示全部楼层
yin99同志,这样不好。你晓得别人不见得晓得。各取所需嘛,^_^感谢楼主。
发表于 2004-5-5 06:26:00 | 显示全部楼层
有沒有ta2o5、 nb2o5、zro2、 mgf2
发表于 2004-5-20 01:44:00 | 显示全部楼层
谢谢
