楼主: 电光
激光器的稳频
发表于 2004-4-25 10:19:00 | 显示全部楼层
我也在做PDH方面的工作,不过国内好像还没见报道。
国外这方面已经很成熟了。
发表于 2004-4-28 07:17:00 | 显示全部楼层
Nothing is easy for PHD technique. It involves a lot of electronic design and accurate optical align system. It would be a big project that takes a few years to finish it.
 楼主| 发表于 2004-4-28 20:46:00 | 显示全部楼层
不会吧,需要这么多年才能完成他,这个只是我的毕业设计的一部分,怪不到当时老师给我说这个题目比较新
发表于 2004-4-30 06:14:00 | 显示全部楼层
It depends on what kind of external cavity you are going to use. For a cavity with F 10,000, it will be really difficult. If you use F = 100, then PDH is not so meaningful any more.
A good suggestion is: if it is really your thesis work, then give it up immidiately and change the plan. 99% you will fail in the thesis if you take this project with high finesse cavity.
Diode pumped Nd:YAG laser would be relatively easy to lock, anyway.
 楼主| 发表于 2004-4-30 06:29:00 | 显示全部楼层
谢谢给我这个建议,我再看看吧,毕竟只是论文的一部分,我再问问老师。
发表于 2004-5-13 06:41:00 | 显示全部楼层
If youteacher said it was a big project ,you will lose faith.In fact , you teacher only let you do some pr-research .
 楼主| 发表于 2004-5-13 06:54:00 | 显示全部楼层
其实是经过纵模分裂后得到双频激光频差的稳定,我想首先单频时必须稳定,经过分裂后双频才有可能稳定
发表于 2009-10-15 16:53:46 | 显示全部楼层
用Pound-Drever-Hall's 方法稳定在mHz的数量级可以实现,但非常困难
