2004-5-12 18:19:00 | 显示全部楼层 | 阅读模式
请大家上去下载更新自己的软件
3618查看15回复
2004-5-13 23:28:00
<P>在哪儿啊</P>
2004-5-14 23:03:00
www.zemax.com
2004-5-15 19:10:00
<b><FONT size=4>April 27, 2004</FONT></b> <P><B>New Features</B> <OL type=1><LI>ZPL keyword RANDOMIZE added to control the seed on the random number generator. <LI>ZPL keyword SETDETECTOR added to set values of detector pixels. <LI>New Biconic Zernike surface added. <LI>The Glass Melt Fit feature has a new option to fit the dispersion data only over the wavelength range defined by the melt data points. This greatly improves the accuracy of the fit at the defined wavelengths. <LI>The automatic semi-diameter calculation is much faster for many common non-axial cases, significantly speeding up optimization for these cases. </LI></OL><P><B>Bug Fixes</B> <OL type=1><LI>The Chromatic Focal Shift Plot was computing the shift in air, even if there is glass up to the image surface. <LI>The optimization operand TOLR was causing unused 0 byte sized files to be created in the \TEMP directory. <LI>A bug in the key driver which could cause a "blue screen of death" has been fixed. </LI></OL><P>第一个更新对于编程(ZPL)是很有用的</P><P>第二个:也很有用,对于杂光分析的编程</P><P>第三个:增加了一种面型,当然是一个比较大的更新了,增加了设计的自由度</P><P>第四个和第五个,相当于完善和优化。</P><P>可惜了,我们单位不批钱给我更新了</P>
2004-6-1 01:21:00
3q3q3q
2004-5-27 02:54:00
有免费ZEMAX软件就好了,正版买不起
2004-6-2 17:49:00
正版的实在太贵了,买不起!不知道哪里有免费的可以下载?
2004-6-4 02:35:00
可惜他们只给在售后服务时间内的客户更新,我的已经过期就不能升级了。
2004-6-5 07:47:00
请问盗版和正版的区别是什么?
2004-6-6 23:21:00
破解版的可以升级吗?
2004-6-12 01:23:00
正版的EE要41000大洋。太贵了。
2004-6-12 03:24:00
没有钱,好郁闷!!!!!
12下一页
