2004-5-19 11:17:00 | 显示全部楼层 | 阅读模式
你的防火墙有用吗?你试一试就知道了!!!
这个网站可以测试你浏览器的安全性和防火墙的性能.点下面的网址,进入后选中" I agree to indemnify and hold TestMyFirewall.com and our service provider harmless from any claim or damage resulting from your use of this service. ",点"Scan"进行扫描.根据网站的说明如果测试时你的光驱自动弹了出来,这说明你的浏览器存在允许执行恶意代码的安全隐患.看看你的网页防火墙好不好使吧! http://www.testmyfirewall.com/spyware_removal.asp
1378查看2回复
2004-5-19 11:17:00
2004-5-19 11:18:00
We completed the audit and did not find any open ports. This is ideal for the average visitor.
Patch-Management.com can help take the worry out of staying current with security updates and patches!
