查看: 4472|回复: 8
请告诉我H4和M2是一种镀膜材料?用在哪些光学薄膜上?谢谢了!!
头像被屏蔽
发表于 2004-6-4 00:55:00 | 显示全部楼层 |阅读模式
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2004-6-4 01:10:00 | 显示全部楼层
Substance H1 highly refractive Patinal®
Granules, about 1.0-1.6 mm 1.16004
Tablets, about 1 g, 10 x 3.5 mm1.11611
Tablets, about 6 g, 14 x 9.5 mm1.13723
Discs, about 6 g, 17.5 x 5.4 mm1.13069
Refractive index
2.1 at 500 nm
Transmission range
360 - 7000 nm
Evaporation temperature2200 - 2400 °C
Evaporation sourcee-beam, W
ApplicationCoatings with high refractive index, multilayers
Product informationOn Request
In the description of tablets or discs, the first parameter is always the diameter, and the second the thickness
发表于 2004-6-4 01:12:00 | 显示全部楼层
Substance H2 highly refractive Patinal®
Granules, about 1-2.5 mm 1.16714
Granules, about 1-4 mm 1.16413
Refractive index
2.1 at 500 nm
Transmission range
400 - 5000 nm
Evaporation temperature2000 - 2200 °C
发表于 2004-6-4 01:13:00 | 显示全部楼层
Substance H4 highly refractive Patinal®
Granules, about 0.1-2 mm 1.15591
Granules, about 1-4 mm1.08332
Refractive index
2.1 at 500 nm
Transmission range
360 - 7000 nm
Evaporation temperature2200 - 2300 °C
ApplicationHighly refractive layers on glass and plastics
发表于 2004-6-4 01:14:00 | 显示全部楼层
Substance M2 medium refractive Patinal®
Granules, about 0.1-2 mm1.08302
Granules, about 1-4 mm 1.09941
Refractive index
1.7 at 500 nm
Transmission range
210 - 10000 nm
ApplicationMedium refractive layers on glass and plastics
发表于 2004-6-4 01:16:00 | 显示全部楼层
Substance H5 highly refractive Patinal®
Granules, about 1-4 mm1.08304
Refractive index
2.2 at 500 nm
Transmission range
350 - 7000 nm
Evaporation temperatureabout 2100 °C
Evaporation sourcee-beam, Mo
头像被屏蔽
 楼主| 发表于 2004-6-4 01:19:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
头像被屏蔽
发表于 2004-6-4 03:10:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2011-5-15 18:07:23 | 显示全部楼层
学习中!!!!
