2004-6-4 04:16:00 | 显示全部楼层 | 阅读模式
<P>版主:</P>
<P>    CODE V里能否设定几种玻璃,然后使用这几种玻璃进行优化?能做到吗?</P>
1706查看2回复
2004-6-4 16:05:00
If you read the document provided by Code V. you will know it can but it is very limited to do this.
If you want optimize the glass in several galss , you must optimize it first. and then through testglass macro to make the
model glass to real glass in your indicate glass table.
in zemax it can do really. first you copy several your selected glass to a new .agf file. then use substitute to hammer it.
(must key in the agf file name in substitute solve dialog box)
2004-6-15 03:53:00
楼上的哥们,请用中文好不好,这儿又不是英语大赛
