查看: 3285|回复: 19
最新版本的zemax(2004-6-11)又出来了!
发表于 2004-6-17 17:31:00 | 显示全部楼层 |阅读模式
<P><b><FONT size=4>新功能如下:</FONT></b></P>
<P><b><FONT size=4>June 11, 2004</FONT></b> </P>
<P><B>New Features</B>
<OL type=1>
<LI>The maximum number of wavelengths per configuration has been increased from 12 to 24.
<LI>POP now uses a more accurate phase handling algorithm for very fast paraxial and other special surface types. The new algorithm reduces aliasing effects.
<LI>POP fiber coupling using a beam DLL now supports the surface vertex reference option.
<LI>The POPD optimization operand now computes the radius given the percent encircled energy.
<LI>Optimization operand RELI now computes relative illumination considering polarization.
<LI>The geometric encircled energy and GENC/GENF operands all now support a "middle" coordinate reference point.
<LI>The NSC Toroidal Lens object now supports elliptical as well as rectangular and circular aperture shapes.
<LI>New NSC filters X_GHOST and X_SCATTER allow selection of only rays which ghost or scatter a specific number of times.
<LI>Ray tracing to the NSC Detector Surface object is now dramatically faster; as much as 2,000 times faster for detectors with thousands of pixels.
<LI>CAD Export now supports a user selectable tolerance dimension.
<LI>ZPL keyword SOLVETYPE now supports codes for turning off common solves.
<LI>A new option has been added to compute F/#'s using the exit pupil size and position; the method has some application in systems with extremely large image conjugates.
<LI>The Grid Phase surface now supports a shear distance parameter, which models phase shear with respect to field angle. The new feature is used for modeling atmospheric turbulence.
<LI>New optimization operand WLEN returns wavelength value in microns.
<LI>The real image height aiming algorithm now more reliably handles z rotations of the image surface. </LI></OL>
发表于 2004-6-17 17:35:00 | 显示全部楼层
好呀,不知道什么时候能D出来
发表于 2004-6-18 02:29:00 | 显示全部楼层
哪儿有啊,共享一下吧
发表于 2004-6-26 18:01:00 | 显示全部楼层
<>顶,贡献一下啊!在哪儿能找到啊!发到邮箱吧!<a href="mailtlieyingfly@sohu.com" target="_blank" >lieyingfly@sohu.com</A></P>
发表于 2004-6-27 17:29:00 | 显示全部楼层
4楼的小蝇飞翔。。。你也用这个啊???
楼主,不知道网上有没有这个啊???我去找找去,,,,
楼主能不能提供消息呢???
lizengqiang111@163.com
发表于 2004-6-30 03:26:00 | 显示全部楼层
<P><a href="mailtcaoqipeng2004@126.com" target="_blank" >caoqipeng2004@126.com</A></P><P>谢谢!</P>
发表于 2004-7-2 03:01:00 | 显示全部楼层
ok
发表于 2004-7-2 18:39:00 | 显示全部楼层
好东西一起分享吧,
mailtomatao@126.com
发表于 2004-7-3 17:31:00 | 显示全部楼层
ZENAX好象没有下载呀
发表于 2004-7-3 19:25:00 | 显示全部楼层
能不能D出来啊,知道这个但是用不到,没有用
发表于 2004-7-6 23:00:00 | 显示全部楼层
很难找,只要试用软件,谁有正式版本的?
发表于 2004-7-6 23:19:00 | 显示全部楼层
好东西不要忘了分享哦
