2004-7-2 06:32:00 | 显示全部楼层 | 阅读模式
看看你的防火墙好不好使 这个网站可以测试你浏览器的安全性和防火墙的性能.点下面的网址,进入后选中"I agree....",点"Scan"进行扫描.根据网站的说明如果测试时你的光驱自动弹了出来,这说明你的浏览器存在允许执行恶意代码的安全隐患.看看你的网页防火墙好不好使吧! http://www.testmyfirewall.com/spyware_removal.asp
1315查看4回复
2004-7-2 06:33:00
This spyware removal test takes a 4 phase approach, a virus and trojan port scan, a standard port scan, a spyware test and a browser security test. The results of the spyware removal test are presented on one page. Here is how it works:
  • The virus test checks for ports commonly used by trojans and viruses while the standard test scans for services running on the first 1500 ports. Open ports are what hackers look for and usually indicate a security risk. If we find any, we'll let you know!
  • The Spyware removal test checks for programs that invade your privacy and will provide instructions on how to remove spyware, if found. The browser test will attempt to eject your cd-rom or dvd.
If nothing happens or you don't receive results, then you'll want to temporarily disable the auto Block feature on your firewall. Some firewalls permanently block an IP address if it detects a port scan.
Don't forget to visit our Links section for free pop up blocker, firewall and antivirus software!
I agree to indemnify and hold TestMyFirewall.com and our service provider harmless from any claim or damage resulting from your use of this service.
2004-7-2 06:34:00
Scan in progress - may take 10-80 seconds
While your waiting, why not visit Patch-Management.com and pick up free patch management software. Take the worry out of staying current with security updates and patches!
2004-7-2 06:34:00
We completed the audit and did not find any open ports. This is ideal for the average visitor.
Patch-Management.com can help take the worry out of staying current with security updates and patches!
2004-7-5 02:06:00
我的光驱手工都弹不出来了
