<P><FONT face=Arial color=navy size=2>Creating large lens arrays is very easy in NSC mode in ZEMAX. If possible, try to make use of the Lenslet 1 or Lenslet 2 objects which have built-in arraying capabilities. Otherwise, you can use the “Replicate Object Tool” (accessed via the menu option, “Tools Miscellaneous Replicate Object”) to create an array out of any NSC object.</FONT></P>
surface type 里面user defined surface dll选us-array.dll 这样surface type 栏就出现lens array 这行中会有radius , thickness, number x ,number y, width x ,height y 按自己所需填写就行了
