查看: 5586|回复: 17
相对照度的优化,急!
发表于 2004-7-15 06:28:00 | 显示全部楼层 |阅读模式
<P><FONT size=3>小弟目前正在进行手机镜头的设计,周边相对照度很低。<FONT face="Times New Roman">CODE V</FONT>好像无专门对相对照度进行优化的指令,各位先进能帮小弟解决这个问题?谢谢。</FONT></P>
[此贴子已经被作者于2004-8-22 22:12:48编辑过]
相对照度的优化,急!
相对照度的优化,急!
发表于 2004-7-15 21:22:00 | 显示全部楼层
没有吧,自己要去寻找能够减轻cos四次方因子的原始结构。优化后时刻观察计算注意边缘视场的相对照度。
发表于 2004-7-15 21:51:00 | 显示全部楼层
aut;
@RI == (M F2 R2 SI) - (M F2 R3 SI)*(L F2 R4 SI)/(2*(M F1 R2 SI)**2) @RI 0.60 !!第二视场F2的相对亮度大于60%
发表于 2004-7-21 17:14:00 | 显示全部楼层
<>Hi</P><>Above method would still be not correct if you have vigneting or if the shape of the light awl on the cross surface is not close to ellipse.</P><>If someone could write a macro tracing a bound of ray and calculating the solid angle, that would be more correct. </P>
发表于 2004-7-22 05:38:00 | 显示全部楼层
FCT @ill(num ^z,num ^w,num ^x,num ^y)
lcl num ^z ^w ^x ^y ^test ^lum lcl num ^output(10,10) ^pol_input(5) ^pol_input(1)==0 ^axis==tra_1fld(^z,0,0,20,0,1,^pol_input,^output) !TRA_1FLD娭悢傪巊梡偟偰幉忋偺徠搙傪寁嶼 ^lum_axis==^output(4,^w) !曄悢^lum_axis偵偦偺抣傪曐懚
^pol_input(1)==0 ^off==tra_1fld(^z,^x,^y,20,0,1,^pol_input,^output)
^lum_off==^output(4,^w)
^rel_ill==^lum_off/^lum_axis
END FCT ^rel_ill
save above txt as one ill.seq
below is the usage sample:
dro fct @ill! delete this fct if it exist
res cv_lens:triplet! sample
in ILL! load above macro fct
lvr! list the var
aut
efl = 100
@ill(1,2,0,20) = 0.5! field at 20 degree 's relative illumination is 0.5
wtc 1
dra sa
go
wri @ill(Zoomk,wave,X direction field ,Y direction field) ! curent value confirm
 楼主| 发表于 2004-8-9 05:00:00 | 显示全部楼层
Thanks
 楼主| 发表于 2004-10-20 07:08:00 | 显示全部楼层
<b><FONT size=2>…这个宏执行起来似乎有问题!能否再请您确认一下,谢谢。</FONT></b>
发表于 2004-10-20 17:15:00 | 显示全部楼层
要想执行没有问题,建议你读一下关于宏的说明.
 楼主| 发表于 2004-10-21 07:06:00 | 显示全部楼层
Excuse me, the definition of two functions ^output(*,*) ^pol_input(*)
发表于 2004-10-21 22:32:00 | 显示全部楼层
lcl num ^z ^w ^x ^y ^test ^lum lcl num ^output(10,10) ^pol_input(5) ^pol_input(1)==0 ^axis==tra_1fld(^z,0,0,20,0,1,^pol_input,^output) ^lum_axis==^output(4,^w)
END FCT ^rel_ill
发表于 2004-10-21 22:37:00 | 显示全部楼层
将上面的文字拷贝后,在CODEV 命令行输入:
edit ill
出现CVEDITOR的窗口后,将其粘贴上去.保存.
再执行 in ill
就可以在优化过程中调用此函数了.
验证此函数:在命令窗口中输入:
write @ill(1,1,0,2.6)
其中的参数的意义为:
1.ZOOM 位置,没有多重结构的输入 1
2.要计算相对亮度的波长,
3.X视场,不是第几视场,用视场实际值.
4.Y视场,同上.
如果你还是不能用的话,就说明你的宏不了解.
建议你多读一些CODEV关于宏的说明. 我讲的已经很详细了.
发表于 2004-10-21 22:46:00 | 显示全部楼层
这是例子. 在这个例子之前还要运行命令: in ill
