楼主: victorrose
相对照度的优化,急!
 楼主| 发表于 2004-10-22 07:17:00 | 显示全部楼层
Thanks
发表于 2005-5-13 01:09:00 | 显示全部楼层
redflag:你能发给我一份CODEV软件安装吗?我的软件是正版的,但是被人借走了,现在又要用,你如果有的话麻烦发一份,可以有一定酬谢!!jianqindx@sohu.com
发表于 2005-7-13 18:19:00 | 显示全部楼层
You can use the simple formula define as blow:
aut;
@RI == (M F2 R2 SI) - (M F2 R3 SI)*(L F2 R4 SI)/(2*(M F1 R2 SI)**2)
@RI > 0.60 !!第二视场F2的相对亮度大于60%
发表于 2005-7-13 04:14:00 | 显示全部楼层
Dear Redflag,
Please help
When simulate to use @ill function, it become very very slow......my god...
发表于 2005-7-14 17:31:00 | 显示全部楼层
[B]以下是引用[I]redflag[/I]在2005-7-13 10:19:17的发言:[/B][BR]You can use the simple formula define as blow:
aut;
Sorry, Redflag,
The result of above equation seem can't match MTF's relative illumination result for desired field.
发表于 2005-7-14 17:34:00 | 显示全部楼层
IT IS JUST FOR REFERENCE. IF YOU WANT CONTROL IT AS REALLY, USE MY MACRO FUNCTION. BUT IT IS NOT FAST AS THIS.
