Southern Photonics 公司TLS150是一款高性价比的连续输出(CW)通讯波段可调谐激光器,输出线宽小于100kHz,调谐范围覆盖C波段及L波段,调谐精度为10ps(0.01nm)。借助其极具竞争力的价格,高输出功率和窄线宽及宽调谐范围TLS150被广泛应用于包括coherent detection of high speed complex modulation formats、DWDM、无源器件检测、光学他侧气集成等各种工业是科研领域中。为了方面DWDM测量,TLS150还可以工作在ITU-grid模式下。
特点:
C & L波段高调谐分辨率
ITU-Grid模式 s
窄线宽:100 kHz
高输出功率:13.5 dBm, 功率所有波厂上保持恒定
输出功率可调
独立工作或电脑控制两种方式
Polarization extinction ratio
>20 dB (100:1) at the PM fiber output
RIN for 13 dBm output power
<-145 dB/Hz
Output fiber type
FC/PC PM
Dimensions
230(W) x 260(D) x 100(H) mm
Weight
3 kg
PC interface method
USB 2.0
Minimum PC requirements
Pentium 4, 1 GB RAM, USB 2.0
Power supply
100-240 V 50-60 Hz
* When in ITU-grid mode, high resolution tunability is disabled and tuning is only allowed between 25GHz spacing ITU grid channels.
** Varies slightly depending on the wavelength
*** The laser uses a small FM dethering as part of its wavelength locking mechanism. The instantaneous linewidth is measured over a 1ms integration time.
All specifications are subject to change without notice. Please check with us for the latest specifications.
