查看: 2416|回复: 0
[供应] EPX现货库存, 长期订购
发表于 2011-12-21 16:37:58 | 显示全部楼层 |阅读模式
EPX 开关!
SPDT单刀双掷開關的作用:
  是用来把一个常规的一路微波信号转换成两路输出信号,特征阻抗是50欧姆,这种开关可提供磁保持和故障保护开关两种模式。对于磁保持開關来说,当电源切断后,開關仍然被设置在输入控制电压的位置。如果是故障保护開關,控制电压中断后,会回到所选择的(故障保护)或关闭位置。
  其它选项包括指示器接点位置,标准机身或窄型尺寸,以及可选择的连接器。具体参看型号编号系统。
 技术指标说明:
Switch Type:开关类型    Electromechanical, Coaxial 电子机械、同轴
RF Contacts:RF装置     Break Before Make,开启前为断开
Actuator:激励装置     Latching, Failsafe, 障碍保护、磁保护,12/15/24/28 VDC
Switching Time:转换时间  20ms(max.)
Connectors:连接型式    SMA / N / TNC(female)
Temperature Range:温度范围 -25 o C to +65 o C
Humidity:湿度       Moisture Seal Available(自选)
Shock:冲击        MIL-STD-202 Method 213, Condition D (500G Non Operating)
Vibration:振荡      MIL-STD-202 Method 214, Condition D (10G RMS Non Operating)
Operating Life:使用寿命  1 Million Cycles(min.)
MTBF:平均无故障时间    Over 1 Million Hours (MIL-HDBK-217F Fixed, 25 o C, <1 cycle per hour)
Datasheet:        SPDT_v2.pdf
           SPDT. SMA. DC-18GHz
 Model          Descriptions          Datasheet
SPDT-0001-18-12  Failsafe without Indicator,12VDC    Datasheet
SPDT-0A-18A-N   Failsafe without Indicator, 12VDC,
              Narrow Body           Datasheet
SPDT-0A-18A-D   Failsafe without Indicator,12VDC,TTL  Datasheet
SPDT-0A-18A-T   Failsafe without Indicator,12VDC,
            Internal Termination        Datasheet
SPDT-0A-18B    Failsafe without Indicator,15VDC    Datasheet
SPDT-0A-18B-N   Failsafe without Indicator,15VDC,
SPDT-0A-18B-D   Failsafe without Indicator,15VDC,TTL  Datasheet
SPDT-0A-18B-T   Failsafe without Indicator,15VDC,
SPDT-0001-18    Failsafe without Indicator,28VDC    Datasheet
SPDT-0A-18C-N   Failsafe without Indicator,28VDC,
SPDT-0A-18C-D   Failsafe without Indicator,28VDC,TTL  Datasheet
SPDT-0A-18C-T   Failsafe without Indicator,28VDC,
SPDT-0A-18D    Failsafe without Indicator,24VDC    Datasheet
SPDT-0A-18D-N   Failsafe without Indicator,24VDC,
SPDT-0A-18D-D   Failsafe without Indicator,24VDC,TTL  Datasheet
SPDT-0A-18D-T   Failsafe without Indicator,24VDC,
SPDT-0B-18A    Failsafe with Indicator,12VDC      Datasheet
SPDT-0B-18A-D   Failsafe with Indicator,12VDC,TTL    Datasheet
SPDT-0B-18B    Failsafe with Indicator,15VDC      Datasheet
SPDT-0B-18B-D   Failsafe with Indicator,15VDC,TTL    Datasheet
SPDT-0B-18C    Failsafe with Indicator,28VDC      Datasheet
SPDT-0B-18C-D   Failsafe with Indicator,28VDC,TTL    Datasheet
SPDT-0B-18D    Failsafe with Indicator,24VDC      Datasheet
SPDT-0B-18D-D   Failsafe with Indicator,24VDC,TTL    Datasheet
SPDT-0C-18A    Latching without Indicator,12VDC    Datasheet
SPDT-0C-18A-D   Latching without Indicator,12VDC,TTL  Datasheet
SPDT-0C-18B    Latching without Indicator,15VDC    Datasheet
SPDT-0C-18B-D   Latching without Indicator,15VDC,TTL  Datasheet
SPDT-0C-18C    Latching without Indicator,28VDC    Datasheet
SPDT-0C-18C-D   Latching without Indicator,28VDC,TTL  Datasheet
SPDT-0C-18D    Latching without Indicator,24VDC    Datasheet
SPDT-0C-18D-D   Latching without Indicator,24VDC,TTL  Datasheet
            SPDT. N. DC-12GHz
SPDT-1A-12A    Failsafe without Indicator,12VDC    Datasheet
SPDT-1A-12A-D   Failsafe without Indicator,12VDC,TTL  Datasheet
SPDT-1A-12C    Failsafe without Indicator,12VDC    Datasheet
SPDT-1A-12C-D   Failsafe without Indicator,12VDC,TTL
SPDT-1C-12C    Latching without Indicator,12VDC
SPDT-1C-12C-D   Latching without Indicator,12VDC,TTL
EPX现货库存, 长期订购!
深圳市今创奇科技发展有限公司
JCN TECHNOLOGY CO.,LTD
TEL : 86-755-88262760/ 82029425
页: [1]
