Ultrafast Innovations 公司是专注于镜片镀膜以及色散控制的公司,其产品主要用于超快激光系统,极紫外光源应用,并提供定制服务。Ultrafast仅仅跟随当今科学界的最近研究动向,并且在超快激光、极紫外光源等领域具有非常丰富的经验。
UltraFast Innovations is a premium manufacturer of custom-made optics. Our products cover the spectrum from the UV-VIS-IR range all the way to the XUV-range. We are specialized in the design and manufacturing of optical elements tailor-made for ultrafast laser applications. We have design and manufacturing capabilities for dielectric optics for laser applications, as well as for metallic multilayer structures for x-ray applications. By providing an integral consulting approach to our customers, we are helping them to find the optics that exactly suits their requirements.
请联系 刘先生 Mob 13927443410 QQ 121206359,Email: mrliuyugang@163.com。更多详细产品资料和解决方案请参见http://g1983111.cn.alibaba.com/.
超宽带色散镜
Ultrafast Innovations 的超宽带压缩镜款式多,特别是近红外区域,能实现高达1.5 倍频程的带宽。可以用于啁啾Ti:sapphire 放大器系统,
宽带振荡器或其他应用中脉冲宽度的压缩。用该系列镜片,最低已经获得了3fs 的脉冲宽度。
As examples, the dispersion and reflectivity curves of complementary mirror pairs for 500-1050nm, resp. 600-1400nm wavelength are shown. Solid lines depict the mirror design, whereas dashed lines show measured values.
主要特点:
Output pulses at the Fourier-limit. The mirrors in the ADMC are designed according to your target design curve.
Output pulses free from angular chirp and pulse front tilt.
Higher output power by increased throughput.
Robustness and user-friendliness.
Compact setup size.
The FROG traces shown here are from a 1 kHz-CPA-system with ADMC (left) and prism compressor (right). The ADMC enabled the generation of bandwidth-limited 19 fs pulses with Gaussian beam profile.
极紫外/红外 脉冲延迟单元 XUV/IR-pulse delay unit
极紫外光谱仪、声谱仪 XUV spectrograph
特点:
Flat-field grazing-incidence spectrograph
Wavelength range from 5 to 80 nm
Optional wavelength range 1 to 5 nm
Three different geometry options
Flexible choice of detectors: x-ray CCD-camera or MCP/fiber taper system
Operating pressure <10-6 mbar
Customizable according to user requirements
极紫外单色仪 XUV multilayer monochromator
极紫外多层单色仪,极紫外多阶单色仪,极紫外单色仪,深紫外单色仪,紫外单色仪
High-throughput scanning monochromator
Several energy ranges available
Automated switching between energy ranges
Exit slit focusing
Software control included
Upgrade to UHV technology available
Oil-free pump system
Integrated beam diagnostics available
性能
Up to 11 orders of magnitude signal dynamics with only 100 uJ pulse energy.
Discrimination of pre- and post-pulses.
Scan range exceeding 600 ps in standard setup. Long-range version with 2 ns scanning range available.
Easy to set up and align.
Optimal suppression of background signal by non-collinear sequential third harmonic generation.
Full software package allowing automatic scan of different positions at different resolutions.
Post-processing software for viewing and analyzing the autocorrelation traces.
特点
Signal dynamics: 11 orders of magnitude
Pulse energy for full dynamic range: 100 uJ
Delay range: 650 ps (2 ns optional)
Spectral range: customizable in a wide range
Resolution optical / translation stage: 100 fs / 1 fs
Footprint: 30x40 cm
