查看: 5040|回复: 2
zemax 12 功能有很大的变化!
发表于 2012-2-1 13:34:46 | 显示全部楼层 |阅读模式
Radiant Zemax is proud to announce the release of Zemax 12 and the unveiling of our most powerful edition yet:  Zemax 12 IE, the complete solution for Optical and Illumination System design.
WHAT’S NEW IN Zemax 12 IE
·         PartLinkTM for SolidWorks: Allows users to dynamically modify native SolidWorks part files within the Zemax 12 environment, eliminating import, export, and translation of files.
·         Radiant Source ModelsTM: An industry first, providing unsurpassed accuracy of simulation results.  Zemax12 IE directly reads Radiant Source ModelsTM, allowing users to generate and launch custom ray sets using actual, measured spatial and angular data.
·         Reverse RadianceTM:  A revolutionary tool which reduces analysis time by tracing rays from a specific area of interest back to the source using luminous intensity measured directly from the Radiant Source ModelsTM.
·         Advanced Path Analysis:  Breaks down light into constituent paths to eliminate glint, glare, and problem light in non-sequential designs.  Light paths and energy distribution are summarized into easy to understand visual and table formats.
发表于 2012-2-6 13:20:43 | 显示全部楼层
发表于 2012-2-15 22:39:58 | 显示全部楼层
http://www.optotek.com.cn/news-article-id-389.html
