查看: 3339|回复: 2
[产品] ASAP
 火.. [复制链接]
发表于 2012-2-19 10:37:23 | 显示全部楼层 |阅读模式
ASAP® is powered by the ASAP non-sequential ray-tracing engine — known throughout the optics industry for its accuracy and efficiency. Rays can encounter surfaces in any order and any number of times, with automatic ray splitting. Optimized for speed, ASAP will trace millions of rays in minutes.
Use ASAP to model complex imaging systems, illumination systems, and light-concentrating devices. Create highly accurate source models using source images, point sources, ray grids, and fans. Model incandescent bulbs, LEDs, CCFLs, and HID arc lamps, or import from the BRO Light Source Library. Perform the analyses necessary to validate your designs without experimental prototyping.
Customers in need of CAD software solutions may also purchase a license of SolidWorks® 3D CAD software to complement their ASAP optical software solution. Multiple configurations of SolidWorks Parts, Assemblies, and Drawings are available. SolidWorks is an intuitive 3D-design environment optimized for use with ASAP. Write ASAP geometry files from within SolidWorks, import XML files, or use BRO's proprietary smartIGES™ system to import system models from SolidWorks and other CAD packages while maintaining fast, efficient ray-tracing speed.
ASAP includes a distributed-processing capability allowing you to complete big design jobs in a fraction of the time required by other tools — spawn up to 5 additional ASAP sessions on your Local Area Network (LAN), without leaving your desk.
SAP.txt
18 Bytes, 下载次数: 3, 下载积分: 光电贝 -1 元
 楼主| 发表于 2012-2-19 10:40:51 | 显示全部楼层
需要的可以留下邮箱
发表于 2012-2-19 13:51:00 | 显示全部楼层
楼主发一份给我, 谢谢!  hope2011@139.com
