查看: 3172|回复: 0
[供应] 液晶型径向/角向偏振片
发表于 2012-2-21 09:39:12 | 显示全部楼层 |阅读模式
液晶型径向偏振光起偏器器(Radially Polarization Converter)及角向偏振起偏器(Azimuthally Polarization Converter,方位角偏振光发生器)能够将传统的线偏振光束转化为径向偏振光或者角向偏振光,并且可以在径向偏振光和角向偏振光之间进行切换。可使用350~1700nm波长范围。
wavelength range
  350-1700 nm
active area
  10 mm diameter
transmission
  better than 75% (in the VIS)
retarder material
  Nematic Liquid-Crystal
Substrates material
  Glass bk7
Local extinction ratio (input Intensity/ouput intensity)   when placed between crossed polarizers
  ~100 @ 633nm
Output intensity homogenity
  < 1/100 RMS variation
temperature range
  15°-35°
Save operating limit
  500 W/cm2 CW
300 mJ/cm2 10 ns, visible
200 mJ/cm2 10 ns, 1064 nm
Total size of the housing
  6 cm x 4 cm x 1.5 cm
详情请咨询昊量光电设备有限公司
13295250668315.pdf
