查看: 2336|回复: 0
[供应] 红光/近红外VCSEL
发表于 2012-3-8 15:33:25 | 显示全部楼层 |阅读模式
美国Vixar公司是世界领先的垂直腔面发射激光器 (VCSEL laser)生产商。美国Vixar公司提供各种波长及封装形式的高性能、高性价比VCSEL激光器及VCSEL模块,广泛应用于工业传感、办公设备、生物医疗及国防工业等领域。
特点:
可见到近红外
超窄的线宽
超低的功耗
极高的光束质量
高偏振比
线阵或面阵设计
各种封装形式
单横模或多横模
常见应用:
医疗传感
分析仪器
条形码扫描
激光扫描单元
工业传感
原子钟
塑料光纤通信
Wavelength
  mW Output (1)
  Generic Part Number(2)
  Notes
         Single Mode VCSELs - Single Lasers
670-690 nm
  0.7 mW
  680S-0000-x0y1(2)
  Line width < 0.1nm.
670-690 nm
  0.7 mW
  680Q-0000-x0y1(2)
  0.4nm<Line width< 1.2nm.
790-800 nm
  0.15 mW
  795S-0000-x0y1(2)
  Wavelength tolerance±2.0nm.
795 nm
  0.15 mW
  795S-0000-x0y2(2)
  Wavelength tolerance±0.5nm.
795 nm
  0.15 mW
  795S-0000-xCy1(2)
  Integrated TEC for wavelength  tolerance±10pm.
Single Mode VCSELs - Arrays
670-690 nm
  0.7 mW(3)
  680Q-0000-xAy1(2)
  1x4 (4 apertures)
请联系上海昊量光电
Communications Grade VCSELs (single laser)
670-690 nm
  3.5 mW
  680C-0000-x0y1(2)
  Up to 3Gbps.
Multi-Mode VCSELs - Single Lasers
670-690 nm
  6 mW
  680M-0000-x0y1(2)
790-800 nm
  3 mW
  795M-0000-x0y1(2)
请联系上海昊量光电
840-860 nm
  1.3 mW
  850M-0000-BCy1(2)
  With integrated monitor photodiode &  temp. sensor
Multi-Mode VCSELs - Arrays
670-690 nm
  2.5 mW(4)
  680M-0000-xAy1(2)
  2x8 (16 apertures)
请联系上海昊量光电
670-690 nm
  30 mW(4)
  680M-0000-xPy1(2)
  4x4 (16 apertures)
请联系上海昊量光电
Multi-Wavelength VCSEL Assemblies
680, 795,
& 850 nm
  1 mW
  MULTM-0000-x0y1(2)
  High Efficiency
680, 795,
& 850 nm
  8 mW
  MULTM-0000-x0y2(2)
  High Power
1) At 25°C and 75% of Peak Output Power
(2) "x" and "y"denote the character positions of options explained in the datasheet for the part number.
(3) Output Power of each of the multiple apertures, which are modulated independently.
(4) This product is a "power array" in which all apertures are electrically connected and modulated together.
