查看: 3353|回复: 2
[技术] 冒一个泡泡
发表于 2012-5-4 18:05:32 | 显示全部楼层 |阅读模式
看了部分帖子,还是把一些目前状晒晒比较好,供网友们收藏
Advanced Optowave Corporation is a premium quality manufacturer of DPSS lasers located in New York, USA and is one of leading industrial laser suppliers.  Optowave has instituted innovative modular designs and flexible laser architectures which enable us to offer a broad range of choices in pulse energies, repetition rates, pulse widths and output wavelengths to fulfill a wide variety of application requirements.
Currently, Optowave provide but not only as following industrial lasers(TEM00,M2<1.1):
1)> 100 W/1064 nm/Q-switched;
2)> 75 W/532 nm/ Q-switched;
3)> 20 mJ/527 nm/Q-switched;
4)>50W/532 nm /CW;
5)>30W/355 nm/Q-switched;
6)> 10W/266 nm /Q-switched;
另,紫外与绿光调Q重复频率已经到了1000KHz,用于一些特殊应用。
激光加工对象太多,激光器种类也很多,激光器这几年发展非常快,还有更多的激光器不断出来,个人估计,激光行业还能够兴旺5年,5年以后,会比较平稳发展。每个行业都有兴衰,激光行业也是如此。
发表于 2012-5-5 16:54:53 | 显示全部楼层
想买这种激光器的,绝对不差钱,所以我看很多还是选相干或者SP,至少给客户打样的时候用的不是其他牌子哈哈
发表于 2012-5-7 08:36:46 | 显示全部楼层
您到底是photonics的马甲 还是photonics是您的马甲
