查看: 2276|回复: 0
[供应] 板式铁氟龙换热器
发表于 2012-7-6 08:37:48 | 显示全部楼层 |阅读模式
氟塑料换热器
Fluoric plastic heat exchangers
氟塑料换热器产品特点
1、氟塑料材质采用美国杜邦(TEFLON)、日本大金株式会社(FLON)等进口原料制造;采用先进的制管设备及加工手段,对管束及法兰进行热熔性焊接,组装成换热器;氟塑料(YQ  TEFLON)热交换器适用于表面处理电镀中的镀铬、酸性镀铜、酸性镀锡、镀锌、电解、酸洗化学镀、阳极氧化及化工、医院、食品等腐蚀性溶液的加热、冷却、蒸发、浓缩。
2、氟塑料换热器的性能:采用PFA、FEP、PVDF管材制作换热器材质后,比聚四氟乙稀(PTFE)换热器材质更加优异,并具有更高的稳定性、柔软性、抗裂性及透明性;产品适用湿度范围在—180℃与—260℃之间耐温性极佳,可弯曲成任意形状,但弯曲半径应≥150mm,优异的电绝缘性、不粘性、抗老化性,不论在任何强腐蚀性气体、液体和长期暴露在恶劣的大气中,抗老化性长达10年以上。
3、产品采用YQ-TEFLON(PTFE、FEP、PEA)材料制作而成,根据客户的要求,严格设计产品材质,达到满足工艺的技术条件;产品采用管束(¢3mm、¢5mm、¢6mm、¢12mm)穿入两端法兰组装而成,形成换热器进出口,并用(PP、PVC、PTFE、PVDF框架)组装固定,可防止工件碰撞使换热器损坏。
4、安装时,请按安装图所示及使用说明书。
Features:
1.Fluoric plastic heat exchanger is made by the imported raw material from DuPont (TEFLON) in America and Daikin Industries (FLON) in Japan, produced by hot melt welding. It applies to surface treatment in chrome plating, acid copper plating, acid tin plating, zinc plating, insulation, acid plating, anodizing and chemicals, hospitals, food corrosive heating, cooling, evaporation, as well as condensation.
2. Performance of the products: With the adaption of PFA,FEP and the material of tube heating exchanger, the products is more excellent in stability, flexibility, crack resistance and transparency than PTFE, which fits the temperature range form 180℃ to 260℃. It can be bent into any shape (diameter of the bent part ≥150mm), with the merits of good insulation, non-cohesiveness, age resistance, and its age resistance reaches over 10 years no matter it is under any strong corrosive gas, fluid or exposed under any bad circumstance.
3. The product is made by the material of TEFLON (FEP, PFA) and strictly designed according to the customers' request in order to meet the technical standard. Its tube bundle ranges (Diameter: 3mm,5mm,6mm,12mm), directly connected with the flanges at both ends, which forms the entrance and exit of the heat exchanger, fixed by the frame of PP,PVC,PTFE, PVDF, which protects the accessory from collision.
4. Please use the instruction sheet according to the illustration.
有意购买者请联系QQ:274864783或登录http://www.pcb-yiquan.com.cn查询
