查看: 3392|回复: 2
[供应] KD*P电光Q开关
发表于 2012-11-12 11:01:48 | 显示全部楼层 |阅读模式
E-O Q Switch alters the polarization state of light passing through it when an applied voltage induces birefringence changes in an electro-optic crystal such as KD*P. When used in conjunction with polarizers, these cells can function as optical switches, or laser Q-switches.
Our EO Q-switch employs the finest strain-free, highly deuterated KD*P available. Based on  advanced crystal fabrication and coating technlogy, we can offer a variety of laser wavelengths EO Q switchs which exhibits high transmission (T>97%), high damaged threshold (>500W/cm2 )and high extinction ratio (>1000:1).
Applications:
· OEM laser systems
· Medical/cosmetic lasers
· Versatile R&D laser platforms
· Military & aerospace laser systems
FEATURES BENEFITS
CCI Quality - economically priced Exceptional value
Finest strain-free KD*P High contrast ratio
High damage threshold
Low 1/2 wave voltage
Space efficient Ideal for compact lasers
Ceramic apertures Clean and highly damage-resistant
High contrast ratio Exceptional hold-off
Quick electrical connectors Efficient/reliable installation
Ultra-flat crystals Excellent beam propagation
Electro-optical @ 1064nm
1/4 Wave Voltage: 3.3 kV
Transmitted Wave Front Error : < 1/8 Wave
ICR >2000:1
VCR >1500:1
Capacitance: 6 pF
Damage Threshold > 500 MW / cm2 @1064nm, 10ns
Housing Dimensions EOQ-208 EOQ-210 EOQ-212
Aperture 8 mm 10 mm 12 mm
Length 39 mm 39 mm 45 mm
Diameter 25.35 mm 25.35 mm 25.35 mm
发表于 2012-11-12 21:00:55 | 显示全部楼层
我们有需求,请联系我。
E-mail:marklaser001@yahoo.com.cn
发表于 2014-7-24 00:00:34 | 显示全部楼层
