查看: 2913|回复: 1
[产品] NEW FOCUS微型制动机
发表于 2012-12-3 09:21:39 | 显示全部楼层 |阅读模式
The  Tiny Picomotor actuator is a smaller sized version of our standard Picomotor actuators. We have improved the design so that it will meet even more of your compact-area needs. This version has a 1/4-40 threaded mount with retaining nut.
Model 8354
Travel Range 12.7 mm
Minimum Incremental Motion <30 nm
Maximum Speed 1.0 mm/ min
Axial Load Capacity (+Cx) 13 N
Resolution- Angular <0.6 mrad
Cable Length 2.1 m
Mounting 1/4-40 Thread with retaining nut
Maximum Torque (My) 0.014 Nm
Connector Type 4-Pin
Operating Temperature Range 10-40 °C
Rated Life >1,5x108 steps
             森泉科技有限公司:
            地址:北京市海淀区上地佳园23号楼512室
             邮编:100085
             电话:010-62969271,13717603304
             传真:010-62987021
             邮箱:yhy@sourcescn.com
发表于 2014-7-22 17:17:21 | 显示全部楼层
