查看: 2801|回复: 2
[产品] 1570/2000nm WDM
发表于 2013-3-6 16:55:18 | 显示全部楼层 |阅读模式
1570/2000nm Singlemode Wavelength Division Multiplexer
    The 1570/2000 nm Singlemode Wavelength Division Multiplexer combines light at 793 nm and 2000 nm windows.They offer very low insertion loss and excellent environmental stability.
Specifications
Parameter                                                   Value
793nm Channel                                       1570 ± 20nm
Max. Insertion Loss                                      0.6dB
Min. Isolation @2000 ± 20nm                      13dB
2000nm Channel                                    2000 ± 20nm
Max. Insertion Loss                                      0.9dB
Min. Isolation @793 ± 20nm                        10dB
Max. Polarization Dependent Loss                0.2dB
Thermal Stability                        ≤0.004dB/℃ over -5 °C to +70 °C
Min. Return Loss                                          55dB
Min. Directivity                                             55dB
Max. Optical Power (Continuous Wave)       500mW
Operating Temperature                              -5 to +70℃
Storage Temperature                               -40 to +85℃
*Above specifications are for device without connector.
*For devices with connectors, IL is 0.3dB higher, RL is 5dB lower.
具体订购详情请跟公司销售人员联系。
珠海飞宇光电深圳业务中心
地址:深圳市宝安区龙华鹊山太阳能硅谷大厦A座14楼
电话:0755-28113498
传真:0755-29048624
Http://www.opticres.com
Email: bgzeng@opticres.com  QQ:1350027351
发表于 2014-7-23 13:44:29 | 显示全部楼层
发表于 2014-7-23 13:44:38 | 显示全部楼层
